It has much greater flow out of the engine due to the removal of the stock systems restriction.
Due to this, i've noticed a big improvement in low to mid range torque throughout the rev range but a reduction in top end. Its not as peaky as before.
I'm begining to think this is because the engine is running lean at the top of the rev range.
Is there a way to adjust this on the carbie. I also want to balance the carbs and tune them properly.
Any ideas or help would be appreciated.
