Need help/advice
kwakadakka
Need help/advice
Post by kwakadakka »
Ok i have a 2001 zx6r and have a heap of race fairings for it, but ive only discovered one big freaking problem. If i put on the race tail how do i get my seat bolted down? Im thinking i might have to remove the undertray.???..but then got all my brake and indicator stuff that i need to put somewhere and i also have to disengage the enrty that you use to lift the pillion seat of...
I do track days and ride on the road so i need the idicators and brake light, but is there any possible way to get the seat on or is it just the fact i have to remove the undertray???n but im worried its more probs then its worth...
Im hoping its an easy situatio
Please someone help me out i gotta track day to attend in less then a week!! :shock:
Rusty
Re: Need help/advice
Post by Rusty »
My ZX9R has a small hole drilled right under the seat. I just put a speed nut on the seat and bolt it in from underneath.
dave#3
Post by dave#3 »
I built a J series zx6r as a tracky, so I know exactly what you're facing! I cut the undertray back to just after the frame section where the riders seat attaches, and can remove the riders seat by reaching under the ducktail, but, I've found that I can actually take the ducktail on and off without removing the seat too (on my zx9r trackbike and on the zx6r trackbike).
When I first got the 6 it had a race ducktail on it but was used on the road. The previous owner had used a large U bolt which slipped over the tab on the seat and went through the black plastic undertail - this wasn't ideal as the seat moved around too much.
I think if you want to retain your boot space and not hack your undertail to pieces you'll need to attach the seat then slide the ducktail into place - if worst comes to worst you may need to fabricate a bracket that holds the back of the ducktail in such a way as to allow you to put a bolt through from the top of the ducktail into said bracket.
Where's your trackday at???
http://www.oz4x4.net/gallery2
kwakadakka
Cheers thanks heaps for that!
The track day is at Mallala (SA).
Id like to use the duck tail for the road as well and just leave it as is....Ill have a look tomorow and see if i could slip it on with out unbolting the seat...
Thanks heaps
dave#3
Post by dave#3 »
kwakadakka wrote:Cheers thanks heaps for that!
Thanks heaps
Cut a set of holes for the brake lights and you can use it on the road too.
