Which Oil
Naked Twin
Which Oil
I am changing the oil if I can ever get the f**king oil filter off. I have two oil filter removers and none fit.
Anyway
I have an 96 ZX7R, used only for track days, just curious what others maybe using for oil. I have used motul and shell in the past but was just wondering what others are using on a slightly older model bike?
Just throwing this out there, a friend (well I know him) says he uses standard car engine oil (mobil full syn.) when he changes his engine oil and has never had clutch slipping or engine problems with is bike. Is this possible as I thought or was told the friction modifiers would kill a clutch.
Nick
Anyway
Nick
- MadKaw
- Administrator
Re: Which Oil
Depends whats on sale..
Castrol R can be picked up from super cheap for about $56, but I stock up on the 20% of sales ($45). Its full synthetic 5w 40. They sell if for the same price as the gps semi synthetic.. I use that in the 10
But generally, any semi synthetic 10w 40 motorcycle will be fine and can be bought for under $40 if ya look around, so I wouldn't go with car stuff as the $ aren't much better.
I bought some repsol semi 10w 40 from Autobahn a while back for $36.. thats for the 7...
Having said that, try to stick with the same oil as varying the oil type at changes can cause additional wear and sludge build up..
MiG
Re: Which Oil
The undesirable friction modifiers are in energy saving oils and possibly in some of the very low viscosity ones. The majority of car oils work just fine. I use Shell Rimula Super in the GPX. It's a diesel oil.
KTM 640LC4 Supermoto, Booya!
Re: Which Oil
Its interesting that you mention Rimula X. One of the boys up here on CanberraRIDERS who knows his way around engines, swears by this stuff - he uses it in his GTR1000, and reckons it comes out after 10k just as clean as when it goes in....
- dave#3
- Team Ninja
Re: Which Oil
It's pretty good diesel oil, but I found my diesel 'cruisers ran better with Penrite HPR30 Diesel ... maybe you fella's could try it in your bikesGosling1 wrote:Its interesting that you mention Rimula X. One of the boys up here on CanberraRIDERS who knows his way around engines, swears by this stuff - he uses it in his GTR1000, and reckons it comes out after 10k just as clean as when it goes in....
http://www.oz4x4.net/gallery2
Re: Which Oil
I'll keep using Motul 5100 in the MFP12, was thinking more about using Rimula ( or maybe even Penrite) in the old dungers ?? I'd reckon the little 6fiddy would go OK on this stuff, and its pretty cheap when you buy it by the 200-litre drum !!
katanaman
- Bike: ZX7R
- State: Northern Territory
Re: Which Oil
rimula X for me as well, have used it for years in everything, road racing ZX7/9.5, My KTM 525 that has done 3 finkes (top 50), Kamfari (2nd in old farts), 4,6 and12 hour enduros, and 2 Simpson crossings without ever comming apart, even for rings!!! Also use it in the Triumph and both cars. best to buy it in 20l drums when on special at Super cheap or equiv.
Use what ever you want, just change it all the time.
Re: Which Oil
Did the oil oin the little zeddy yesterday the change happens every 5k & went to buy my usual 5100
damn its gawn up another $10 & now costs $56 for 4 Ltr bit farkin rich but not as much as the silkoline Started from $80 something
Have used the 5100 (10w40) for many years.....been told the 40 is better then the 10w50 but they are the same cost.
Re: Which Oil
If it comes out clean, doesn't that mean it's not workin good ?Gosling1 wrote:Its interesting that you mention Rimula X. One of the boys up here on CanberraRIDERS who knows his way around engines, swears by this stuff - he uses it in his GTR1000, and reckons it comes out after 10k just as clean as when it goes in....
Go Supercheap, Im using the Full Synth GP Castrol shit..
