03 ZX9-R won't change gears!!
My mate has a major drama with his 9.
It will change from 1st to Neutral alright, but you can't get in into second or the rest of the gears.
We've pulled the clutch cover off to check out the shift/selector mechanism which appears fine.
Exhaust and sump has come off to inspect the transmission itself which shows no sign of any damage either.
For some reason we can't figure out it's like the shift drum gets stuck and won't rotate beyond neutral.
Any ideas??
Any ideas??
- Team Naked
Re: 03 ZX9-R won't change gears!!
Mick C from Canberra has a thing on his homepage about rebuilding a ZX9 gearbox, but if everything looks ok that might be a bit drastic, changed oil recently?
- jl4049
Have you removed all the shift lever linkages and cleaned and lubed them? For some reason ZX9s are really ensitive to the slightest amount of gummed upness in the lever pivots and linkage swivels.
C1 ZX9R
Is this on the move, or standing still?
Positive Neutral Finder locks out 2nd at a standstill.
- Neka79
- Extreme Post Whore :-)
- Bike: Z900
i was thinking the same thing....Rusty wrote:Is this on the move, or standing still?
no matter how hard u try... lol.. when sitting still u wont get 2nd...
The suspense is killing me!Rusty wrote:Is this on the move, or standing still?
KTM 640LC4 Supermoto, Booya!
- z900/zx9
Yep remove the shifter and pegs etc and clean and grease,thats what fixed mine
Oh and neka mine changes up and down fine while standing still
- Rossi
z900/zx9 wrote:Yep remove the shifter and pegs etc and clean and grease,thats what fixed mineOh and neka mine changes up and down fine while standing still
Well.........it shouldn't
- Sulli
Only way that happens is while burning the back rubberRossi wrote:z900/zx9 wrote:Yep remove the shifter and pegs etc and clean and grease,thats what fixed mineOh and neka mine changes up and down fine while standing still
I'm told it was while trying to find third actually... and the bike was definatley moving.. gonna clean the gear lever and all that stuff, but I've gotta have a bit more of a look at this nuetral finder. I have a feeling it might be causing some dramas too...
- mike-s
i think looking into things much further than just cleaning the selector mechanism at the side is pretty much engine out, split the cases kinda material, so heaps of fun if that is the case... oh and the positive neutral finder really only applies when going from neutral to second, unless i've got things confused here.
In any case from what i've heard if it ever does come down to an engine out-split cases thing it should be reasonably self evident what's broken or bent. Good luck with it, hopefully the external selector is just being iffy.
Here's my article on what I had to do to my 9's gearbox http://www.ksrc-au.com/index.php?itemid=91
It's a bit hard to tell from what you've said if it's the same problem or not, but at least it should give you a bit of an idea what you should be looking for. The 03 gearbox was an improvement over the 98 model too.
- Bike: ZX7R
- State: Northern Territory
Sounds like a broken pin on the selector drum to me. On the earlier models this was behind a cover that was behind the front sprocket, not sure on the later models though. was an easy fix on mine without engine splitting.
