GPX 250 sluggish
- billwest
- Bike: ZZR1200
- State: Western Australia
GPX 250 sluggish
My son's GPX250 ('04) - 13,440 km - is getting a bit sluggish.
It is OK in the morning when it is reasonably cool, but in the afternoon, when the weather is hotter (32+ degrees here) the engine becomes sluggish. Today, with 35 degree heat, he said that the gearbox is getting noisier and notchy as well.
My guess is that the oil is too hot, and also that blow-by via the crank-case breather is causing the carbs to suck in other than fresh air.
Am I right?
Thanks,
Bill.
Am I right?
Thanks,
Bill.
Ride as if you own the bike!
ZZR1200 ('02), FJR1300 ('19).
- Slow and wobbly
- Bike: Scooter
Re: GPX 250 sluggish
Last service was when? And what was done?
New oil may improve the gearbox. Valve clearances and a carb balance may improve the rest.
- Neka79
- Extreme Post Whore :-)
- Bike: Z900
maybe the hot weather is making the bike run hotter, and the oil thinner or sumthin??
my bike runs better in colder weather- more air when its colder and denser... can run like a pig in the heat...
yea.. when was last service etc??
plus.. its a gpx.. they are sluggish at the best of times...lol
MiG
Has the air filter ever been cleaned? If it's running rich due to a restricted air filter it will get worse with higher air temperatures.
KTM 640LC4 Supermoto, Booya!
- billwest
- Bike: ZZR1200
Last service - last month. New oil (Motul 15W50).
Air filter: K&N, clean.
Valves, carbs etc all serviced/adjusted/balanced.
I may disconnect the crankcase breather hose from the airbox, see if that makes a difference.
This GPX sluggish? Not for a 250, it usually goes like the clappers.
Thanks,
Bill.
Thanks,
Bill.
- Nanna10r
- Team Ninja
Bill did you do it yourself ? or ARE your ASSUMING it was a "some intrigal component of trading Money for services arrangement" ?billwest wrote:Last service - last month. New oil (Motul 15W50).
K&N, clean......... Valves, carbs etc all serviced/adjusted/balanced.
Bill.
sounds to me like the Armour ALL has worn off the seat from the LAST service.
- billwest
- Bike: ZZR1200
LOL!
I did oil, filter, airfilter myself.
WA top dealer and service centre, Mack1 Kawasaki, did the rest! Oh ye of little faith! The bike did come back very clean, though...........
41 degrees here in Perth yesterday, and it actually ran quite reasonably.
Will post when I have found the solution, which won't be this weekend, 'cause I'm off to the Superbikes at Phillip Island.
Bill.
Bill.
- Nanna10r
- Team Ninja
Safe trip Bill,
I've seen it done mate, The Armour all service it's called. Overbooked day, staff member short & no overtime.
"She'll be right, mate."
Let us know if you find anything, ta.
- Gazza
dude had a similar prob
chack that you havent over filled the bike with engine oil .
when i bought my 250 it had to much oil in it and it was idleing rough and also the throtle responce in the high gears at low revs wasnt there.
so i decided to drain the oil out and put the correct amount in and its like a different bike
Gazza
Gazza
2005 zx10r
- billwest
- Bike: ZZR1200
All is good now. I think it may have had a clogged vent hole on the tank. and it was especially noticeable when the weather was hot..
Bill.
Bill.
Good to hear it was an easy fix Bill ... that wont happen again now will itbillwest wrote:All is good now. I think it may have had a clogged vent hole on the tank. and it was especially noticeable when the weather was hot..
Bill.
Does the bike wistle when the tank gets hot? its a good sign when she goes quiet
- IsleofNinja
My Gumby has always whistled when the tank is hot?? blocked breather??robracer wrote:Good to hear it was an easy fix Bill ... that wont happen again now will itbillwest wrote:All is good now. I think it may have had a clogged vent hole on the tank. and it was especially noticeable when the weather was hot..
Bill.![]()
Performance varies from fast to farkin woo hoo !!! (suppose extra 750cc's makes it less noticeable!?)
Sounds like you been here before rob?
06 ZX10r , 95 ZX9r
07 FXST
07 FXST
- billwest
- Bike: ZZR1200
Can't be too hot in Kambalda at the moment, eh?
- IsleofNinja
The Freo doctor don't do much by the time it gets here LOL
Bike tank still talks to ya after a decent ride though!?
06 ZX10r , 95 ZX9r
07 FXST
07 FXST
