clutch for a 05 636.
stuartzx6
Post by stuartzx6 »
I have 40,000km on the bike and it has to get a new clutch.
What are the option out there for me and in your experience which one would be the best??? I think it's only the plates but i dunno
thanks stuart
Stuart with a 05 ZX6
Re: clutch for a 05 636.
i suggest sum1 needs a heavy duty clutch!!
my blade had 70,000km and original clutch.. and im sure phils 110,000km zx9r is still on 1st clutch (only thing hes replaced is battery- ive heard the story a few times)...
how can u need a clutch already??
stuartzx6
Post by stuartzx6 »
i dunno it is just slipping alot. always out or 2nd at about 8,000
stuartzx6 wrote:i dunno it is just slipping alot. always out or 2nd at about 8,000
Get some verniers onto the plates to check thickness and measure the spring lengths.
If all is within tolerance, try scuffing up the metal plates as they may have glazed over.
If the plates are OK try some heavier springs like Barnett or Goodridge...
What oil are you running.?
stuartzx6
Post by stuartzx6 »
I had the bike serviced and they put in Motul full synthetic.
Saki
Post by Saki »
like wat MadKw said...
I remember in my 250cc i ran full synthetic oil and it used to slip for the first few hundred km's then it would bite nicely. Have u tried using a different oil, otherwise try wat madkaw said and pull all the clutch apart and check it out!
up2nogood
Post by up2nogood »
If it is shagged (my old 9's was worn out when I got it, previous owner was a shit rider) surf the net for a US supplier of Barnett gear. Unfortunately it was HEAPS cheaper than local suppliers.
'05 ZX12R
'06 Aprilia Pegaso Trail
stuartzx6
Post by stuartzx6 »
new clutch going in on the weekend. ended up getting plates, springs etc... what oil do you think will be the best. it has 45k on the clock and i do alot of traveling with a few fun rides during the month, i was looking at motul5100 but would like to here any other opinons out there.
Stuart
stuartzx6
Post by stuartzx6 »
Change the clutch and springs witch is going like a dream however still sliping out of 2nd. Next Job I am going to pull the whole engine out and pull out the gearbox over the next few week and have a look at it. I have been informed it might be one a the SYNCROS in the gearbox. so we will see.
zxsixr03
Post by zxsixr03 »
My money is on the the fork selector its easily bent from a clunking gear change
