Just preparing a couple of fairings at the moment, but as they are changing colour, i want to paint the back side aswell.
Can any body tell me what to use to remove the glue? I've tried accetone and thinners so far, but with little success.
Removing glue from back of fairings.
mattyv74
- Team Kitty Litter
- Bike: ZX7R
- Slow and wobbly
- Bike: Scooter
Re: Removing glue from back of fairings.
Depends on the type of glue. If the Acetone and thinners don't shift it then not too sure what else to suggest. Normaly I would use Shellite / white spirit as it is far less aggressive than those other two, especialy on plastics.
Rusty
I got all the (OEM) foam and glue off my ZX9R fairings - I used thinners. It worked, not real well, but better than anything else I tried. I had to let it sit and soften for a while, then used a scouring pad and soapy water. Took a little patience! As you can tell, I wasn't trying to preserve the old paint at all.
Thinners turns the foam into a gloopy mess which clogs up the scourer. I used a really sharp knife (my old filleting knife, actually) to cut as much foam off as I could before having a go at the glue.
L3raven
- Bike: ZX7R
- State: Western Australia
Try M.E.K its a hardcore white base we use at work if it can melt hard hats it should be able 2 remove glue.
Pops the clutch n falls off haha!!
mattyv74
- Team Kitty Litter
- Bike: ZX7R
Thaks guys, will go in for another round and we'll see who wins this time.
- kellz
i used a hairdryer and stanley blade when i removed the glue and crap off the back of alex fairings.
we also used this goop remover we got from coles.
sprayed it on let it sit for a few minutes then heat it all up and off it came. then wiped the small residue off with eucalyptus oil, good quality stuff tho..
- mike-s
could always be plastex they are using, or epoxy resin.....
craig
mike-s wrote:could always be plastex they are using, or epoxy resin.....
which leaves you with lots of scraping with a blade or grind it off with a dremil or die grinder...carefully
