HP gain...
L3raven
- Bike: ZX7R
- State: Western Australia
HP gain...
Wat can i do 3 my 05 636 2 gain power mainly tourqe. it has a Arata ti can with PC3 map'd.
Pops the clutch n falls off haha!!
- photomike666
Re: HP gain...
Hi flow air filter may help , with PCIII map. You could try a high flow oil filter too.
Once you've done air flow (filter), exhaust and timing (maps) it's going to start getting expensive. If money isn't an issue and you were simply after power then alternate cams, bigger valves, having the head gas flowed. polished and ported would be a starting point. Then skim the head to reduce tollerances and increase compresion a smidge, lighter pistons, balance the crank shaft. It's a lot of money for small differences.
You could go the other way and keep the power as is and shave some weight. Perhaps start with the wheels, $2000 will get a set of Dymags shaving some 20Kg off the un spring weight, and I'm sure an after market swingarm would be lighter and maybe stiffer.
If you haven't already done it, go down 1 tooth on the front sprocket, and maybe try and find a quick action throttle. Cheap options for using your available power better in the ridable range of the bike.
- Stereo
Re: HP gain...
Yeah, messing with the sprockets is the quickest and ironically the cheapest way to get more HP to the road quickly.... Think about it.... How often do you actually go 280Kmph? Probably pretty rarely.... so why not dump 30km from the top speed and get all those extra ponies to play with in 2nd to 5th gear!
- GForce
Re: HP gain...
+1 to thatStereo wrote:Yeah, messing with the sprockets is the quickest and ironically the cheapest way to get more HP to the road quickly.... Think about it.... How often do you actually go 280Kmph? Probably pretty rarely.... so why not dump 30km from the top speed and get all those extra ponies to play with in 2nd to 5th gear!
it feels like you gained 10hp through all the gears
- ZX-10R_04
- State: Tasmania
Re: HP gain...
-1 to thatL3raven wrote:Wat can i do 3 my 05 636 2 gain power mainly tourqe. it has a Arata ti can with PC3 map'd.
04 ZX10R & 08 ZX10R
04 ZX10R & 08 ZX10R
L3raven
- Bike: ZX7R
Re: HP gain...
Cheers boy's i'll look im2 the gearin option oh the bike does 278 top end but my av speed i do on open road is 220 240 but cruisin speed with the crew top 100's any idea's on wat ratio i should run back n front?
- RichB
Re: HP gain...
And a quick action throttle
- zxsixr03
Re: HP gain...
Keep the stock front at 15 and just go 2 up in the rear 3 max, much improvement.L3raven wrote:Cheers boy's i'll look im2 the gearin option oh the bike does 278 top end but my av speed i do on open road is 220 240 but cruisin speed with the crew top 100's any idea's on wat ratio i should run back n front?
- ZX-10R_04
- State: Tasmania
Re: HP gain...
http://www.doublezracing.com/" target="_blankRichB wrote:And a quick action throttle
04 ZX10R & 08 ZX10R
04 ZX10R & 08 ZX10R
