1200 CC for Twin Cylinder superbikes.
- Bike: ZXR750
Ducati get their way, 1200cc for twins in 2008 World Superbike Championship
After consultation with all the parties involved and upon the proposal submitted by the Superbike Commission, the FIM has decided the following amendment and additions to the Superbike World Championship technical rules for 2008.
• Displacement capacities.
o 2 cylinders over 850cc up to 1200cc
o 3 cylinders over 750cc up to 1000cc
o 4 cylinders over 750cc up to 1000cc
• Minimum weights.
o 2 cylinders over 850cc up to 1200cc: 168kg
o 4 cylinders over 750cc up to 1000cc: 162kg
Minimum weight of 2 cylinders over 850cc up to 1200cc will be updated, if needed, during the Championship in steps of ±3kg to 171kg as a maximum and 162kg as a minimum.
• Air-restrictors.
Only 2 cylinders over 850cc up to 1200cc will be fitted with air-restrictors. Initial size will be equivalent to a Ø50mm circular area. Air-restrictors size will be updated, if needed, during the Championship in steps of ±2mm of diameter in a range from equivalent to a Ø46mm circular area to no air-restrictor at all.
• Balance of different motorcycle concepts. Weight limit and then air-restrictors size of 2 cylinders over 850cc up to 1200cc machines will be updated, if needed, during the Championship, by a system analysing the race points obtained.
• Tuning level.
All machines will have the same level of tuning presently applied to 4 cylinders over 750cc up to 1000cc, with the exception of connecting rods that must be standard for 2 cylinders over 850cc up to 1200cc.
• Homologation numbers.
For 2008 and 2009 all manufacturers, irrespective of their total production numbers, will have to produce a minimum of 1000 bikes in order to get an homologation.
For 2010 onwards the minimum production number will be increased to 3000 bikes.
The complete set of the new 2008 Superbike technical rules will be issued by FIM during next week.
• Minimum weights.
• Air-restrictors.
• Tuning level.
Bike 93 ZXR750
05 ZRX1200
05 DRZ400
Bike 93 ZXR750
05 ZRX1200
05 DRZ400
- javaman
- Bike: GPz900
Boooo... they can't make a decent 1000
What stops ZX14 to join the race then
http://GPZninja.blogspot.com/
- Nucci
As Ive said a few time already in different places:javaman wrote:Boooo... they can't make a decent 1000What stops ZX14 to join the race then
Ducati have nothing to prove, they can build a kick arse 4 cylinder bike if they want to - are you aware of MotoGP?
They want to continue producing V-Twins for their roadbikes and are finding it hard/expensive to get the 999R to a level of tune that makes it competitive against the inline-4's. There is no way a 1000cc V-twin can be developed to produce the same power as a 1000cc I-4 (im guessing due to volumetric efficiency issues) hence the rule change.
If it wasnt for Troy Bayliss the 999R wouldnt be at the pointy end of the field. But yeah with another 200cc's on board for the 1098R I hope the racing is still good, i.e. the dukes dont run away with it.
If it makes for better racing im all for it.
05 ZX-10R
nothing to see here....
- javaman
- Bike: GPz900
The VTWINS have advantages in terms of Torque, Slim profile, weight, etc ! As for hard/expensive isn't that what racing is about ? Otherwise they just use my bikeNucci wrote:
- Nucci
In regard to weight - from the OP:javaman wrote: The VTWINS have advantages in terms of Torque, Slim profile, weight, etc ! As for hard/expensive isn't that what racing is about ? Otherwise they just use my bike
Minimum weights.
Slim profile? That would hardly be advantageous to the point to knock back a capacity increase for twins.
05 ZX-10R
- Bike: ZXR750
Nucci wrote:As Ive said a few time already in different places:javaman wrote:Boooo... they can't make a decent 1000What stops ZX14 to join the race then
If the Dukes don't run away with it they will just complain again until they get the rules changed to their advantage.
Bike 93 ZXR750
05 ZRX1200
05 DRZ400
Bike 93 ZXR750
05 ZRX1200
05 DRZ400
- HemiDuty
- Bike: Don't have one
One would think (and hope) that Ducati now know the danger to the sport if their bikes (or anyone elses) become to dominant. Hopefully this works out to be very even.
One issue that may become more prevalent is electronics, as the gap between teams with different budgets will widen....
Drmsby Middleton
DC Racing
Extreme Motorsports
M2R
Castrol
ColourSmart Chroming
Hi Side Leathers
Teknic
Sidi
DID Racing Chain
Goodridge
DC Racing
Extreme Motorsports
M2R
Castrol
Hi Side Leathers
Teknic
Sidi
DID Racing Chain
Goodridge
- Neka79
- Extreme Post Whore :-)
- Bike: Z900
saw that last night... at least if the dukes do end up more powerful, they can lift the airbox restrictions ... maybe...
while ur racing apples against oranges, u will always have trouble making them equal..but who wants equal anyway??
one set of rules, they all play by them... honda built a twin to take the title of ducati..kwaka,suzi and yamy can do the same if they see fit...
