Tune/carb clean
Tune/carb clean
hey all
Im just wondering how to clean and tune the carbs in the ol zzr
Hopefully its gonna get reg soon and i wanna get it goin abit more ready
its idling rough varying upto 500 rm lol
so yeah
im thinking clean carbs and tune them (synch?)
its got a single pipe so i think its runnin abit rich so a freer needle might jsut be the go
so yeah any1 got any ideas on how to do that? i just need to be pointed in the right direction koz atm im just looking at my wallet and thinking brighton kawa..... it makes me cry
so yeah
I wish i had wings....
Bikes -
ZZR 600 - FINALLY REGISTERED.... currently in undercoat
x Gpx 250 crap wheelie candidate
x GPZ 250 - push starting magic
Bikes -
Re: Tune/carb clean
Yep, thats a carbie synch needed if ever I heard one....you need vacumn gauges or mercury balance-tubes in order to balance the carbies yourself..... (there is another, much cheaper way to do this, but most people turn their nose up when I mention piano wire....wypuk wrote:....its idling rough varying upto 500 rpm.....
If you *really* want to clean the carbs yourself, you need an air-duster to blow all the internal carbie orifices clean , after giving them a liberal spray with Clean'R'Carb ......
A single pipe ? If its a better-breathing system than stock, it will make your jetting 'leaner', all things being equal. Raising the needles will richen the mixture between 1/4 and 3/4 throttle.......you may need to go up a size or 2 in main jets as well....
Knock yourself out mate.......its heaps of fun doing your own maintenance...
ye ive learned heaps
i jsut want it to idle steady, pick up the front with power (2 inch dont count) and get abit more responsivness
when i get abit of cash together im gonna go -1 front koz i need a new chain anyway
but im seriously lacking power
Bikes -
Bikes -
i dunno if its better or not
but i kno the zzr comes with 2 exhausts n i got one and its carbon fibre lol
and the inside is all mesh with no visible baffles so it makes me think its a resonator lol
also i think its runnin abit rich koz im gettin shitty fuel economy....
Bikes -
Bikes -
bonester
Mate do tell!
Yep, thats a carbie synch needed if ever I heard one....you need vacumn gauges or mercury balance-tubes in order to balance the carbies yourself..... (there is another, much cheaper way to do this, but most people turn their nose up when I mention piano wire.... )
Yeah I like Kawasakis.
Re: Tune/carb clean
I thought the bigger problem was the School of Music getting the shits every time you turn up and lift the cover on the Steinway with a pair of side cutters in your handGosling1 wrote:... (there is another, much cheaper way to do this, but most people turn their nose up when I mention piano wire....![]()
Re: Tune/carb clean
Lookout !! He's on fire !!!Mick C wrote:.......I thought the bigger problem was the School of Music getting the shits every time you turn up and lift the cover on the Steinway with a pair of side cutters in your hand
Its a really old method, its not as good as a mercury-tube balance (the best), but it is *almost* as good as using vacumn guages......bonester wrote:...Mate do tell! ...
using a short piece of piano wire (say about 1mm dia) - not sure what key or note it is
* Wind the idle screw up
*Slide the piano wire into the carby bore, so it goes below and past the slide
* Slowly wind the idle down, at the same time move the piano wire back and forth just a bit (maybe 5mm)
* When the slide touches the piano wire, stop winding the idle down - What you are trying to do is get the slide to *just* catch the piano wire and stop it from sliding back and forth
* Repeat for other cylinder/s
This method will simply get all the slides lifting from almost *exactly* the same idle point, its not *perfect*, but it will sure improve an idle that is fluctuating by 500rpm !!
Now you young whippersnappers, have I told you how to time a bike by using cigarette paper ?? ........yadda yadda......blah blah.......wet fart......
Gos does this method require the removal of the carbies or not?
i had a bad experience on my gpz aand since then i dread carbs lol
also any other painostring method of cleaning them up
like scraping the inside iwth a piano string lol
Bikes -
Bikes -
No, but it does require removal of the airbox and rubber boots behind the carbies, so you can get the wire into the carbie intakes.....wypuk wrote:.....does this method require the removal of the carbies or not?
i had a bad experience on my gpz aand since then i dread carbs lol.....
Nothing beats a proper balance with mercury tubes, this is *the* most accurate way of balancing carbs or injection...
MiG
I reckon my 2 m tall U column filled with ATF fluid will beat it. It's much bigger, but that's what gives it accuracy (I've also pinched the tubes to get the average pressure rather than a rapily fluctuating one).Gosling1 wrote: Nothing beats a proper balance with mercury tubes, this is *the* most accurate way of balancing carbs or injection...
KTM 640LC4 Supermoto, Booya!
