valve clearences on ZZR250
ZZR 250, 600, 1100 & 1200
hoon
Post by hoon »
Hi all,
My ZZR 250 was donw to 80 psi in the left cylinder. Turns out there is no clearnce between the rocker and trhe valve :( Time to reset the clearences,
Its a 2001 ZZR 250. does anyone know what the correct valve clearences are ?
sorry if this has been asked before but nothing came up in seach.
thanks
police now targeting R1s
from memory the intake should be 0.08mm (0.06-0.1 being the acceptable range) and exhaust 0.12mm (0.10 to 0.15mm)
Gnome
Post by Gnome »
Inlet 0.08~0.13mm
Exhaust 0.11~0.16mm
From the official Kwaka ZZR service manual
2001 ZZR250
2x KR250s (anyone wanna buy em' ?)
150cc 4stroke TRICK Bucket (2005-SBL's Ams champion & Most Outstanding Rider)
500cc and 650cc TRICK Supermonos (2006-Bears F5 9th,only did 2 rounds before I f#%ked up)
shoot, i wasnt totally right, but i was close :)
Gnome
Post by Gnome »
You were that close from memory. :o I wish my memory was that good, both of your solid stats were inside tolerence 8) . I'm a ZZR250 nut and I had to look it up. :oops:
2001 ZZR250
helps to have done clearances more than a handfull of times ;)
