Plumbing question
javaman
Bike: GPz900
Plumbing question
Post by javaman »
I need to install a dishwasher, which requires some source of cold water.
Been reading around on plumbing 'techniques' ... what is an easier method of getting water out of a copper pipe, without doing 'flaring' ?
Is there any kit out there which I can easily punch in and screw on ?
Thanks :D
-ariel circa 2007
http://GPZninja.blogspot.com/
ozx6r
Post by ozx6r »
if you want to appear to be a real plumber make sure u r showing a little crack!
97 - zx6r
05 - zx10r
Ben
Post by Ben »
you can buy joiners and t peices from a decent plumming store, push in and they tighten as you pull out with a retaining clip to stop in going back in, about $5 - 10
Never hold in your farts. They travel up your spine, into your brain, and that is where shitty ideas come from!
I thought I saw your name on a loaf of bread today, but when I looked again it said 'Thick Cut'
Felix
State: Overseas
Post by Felix »
You can buy compression "olive" fittings that will do what you want. But proper flared joints are better - you can even buy cheap flare kit from SuperCheap for under/around $20. Wont be quite as tidy as the $300 items though...but may do for a one off.
- Team Furball -
mfzx6r
Post by mfzx6r »
Mate flared joins aint a big deal and puting in a dish washer is no big deal.
PM me on monday and we'll go through what and how sep by step
Mario
'01 zx6r
klx300r
Part of the "Fookarwe" tribe
mfzx6r wrote:Mate flared joins aint a big deal and puting in a dish washer is no big deal.
Of course you'll be free on Monday cause you got to watch the GP the night before - while it actually happened.... :lol:
mfzx6r
Post by mfzx6r »
you got it in one my friend !!!!!!!!! :lol:
Mario
'01 zx6r
klx300r
sunshine
Post by sunshine »
easy pasey andi
you can even get an easy hooker
so you dont have to bend the pipe aroung corners
i think ive got a flaring tool in the shed somewhere ??
its pretty easy to do
rule 1
allways but allways ensure the compression nut is on the pipe before flaring the pipe
rule 2
second ensure the pipe has been cut straight and file any daggy bits
add some teflon tape around thread and tighten compression nut to male thread
rule 3
never attempt this on a sunday as plumbers charge double time on weekdays and triple on sundays :wink:
cheers mick
~LIFES PRETTY STRAIGHT WITHOUT TWISTIES
z1000
Blue14
Re: Plumbing question
Post by Blue14 »
javaman wrote:I need to install a dishwasher, which requires some source of cold water.
Thanks :D
Good piece of advice is hook it up to hot water. Dont rely on the unit to heat water. Just saves a few bucks on the electricity bill.. :wink: Looks like mario has you covered on the rest. :D
I am lucky, father in law is a retired plumber.. 8)
FrogZ
Post by FrogZ »
sunshine wrote:you can even get an easy hooker
I thought they were all pretty "easy" as long as you paid up front ?? :lol:
javaman
Bike: GPz900
Post by javaman »
Thanks all !! Armed with these advises I went to Bunnings and got me one of those compression T- thingy. So no flaring needed (and it works too !!). Was abit worried how the hell it keeps the water in as the idea seems so novel. Must be genius who invented this things. Saves me $30 a.k.a 2 slabs :D.
Now, no more washing dishes !!! Life's good :D
Blue, the instruction says I should connect it to cold water. It can be connected to hot water but won't be as good. Not sure of the rationale though...
-ariel circa 2007
the kid
Post by the kid »
A couple of reasons for conecting to cold water are , some machines have some cycles that are cold only , pre rinse etc . If your machine can be programmed for different temperatures connecting to hot will stuff this feature . Water from the hot water service can be too hot for some glasses and stuff
Gotta love the dishwasher :D
Nanna10r
Post by Nanna10r »
javaman wrote:I need to install a dishwasher, which requires some source of cold water. :D
Get a Pre nubtial Andi & dont forget to put the Water bowl at the end of the chain reach, Quite annoying when you come home from work & they have tipped over their water bowl.
mwahahahahahahahahaha pmsl...
ur on fire ponti...
nice one ponti
