ZZR250 wont idle
ZZR250 wont idle
Hi,
i have a ZZR 250 which doesnt run well around idle. motor just dies when you open the throttle. when the engine is running ove 3 k rpm, motor revs fine.
I have played around with the idle mix screws , didnt make a difference.
The carb boots arent leaking.
any one got any advice? valve clearence maybe ? spark plugs ?
police now targeting R1s
- photomike666
Had this with Zombie's ZZr250, it needed the carbies cleaning big time. They were taken off and soaked in a bucket of carb cleaner over night. Runs fine now.
- Neka79
- Extreme Post Whore :-)
- Bike: Z900
could be any one of the things u listed...start with simple stuff...
clean/replace plugs..amke sure u have spark to every lead...
make sure fuel and air filters are clean... and not blocked/crinmped etc..
then..pull off and clean up carbs..if still a prob... ask us again..lol
Idle mix screws- screw all the way in and then out 2.5 turns
clean carbs by disassembling them, its not that hard, and its the best way to clean the jets, as clean as you possibly can using carby clean and blow parts clean/dry with compressed air
check/clean airfilter
check vacuum lines for leaks, replace
2001 ZZR250
2x KR250s (anyone wanna buy em' ?)
150cc 4stroke TRICK Bucket (2005-SBL's Ams champion & Most Outstanding Rider)
500cc and 650cc TRICK Supermonos (2006-Bears F5 9th,only did 2 rounds before I f#%ked up)
- Team ZZR
Re: ZZR250 wont idle
If you know someone who has another ZZR250 you can try changing the coils. I had a very similar problem and changed the coils from a spare bike I had and it fixed the problem. Just another option.
Simo
Simo
94' "In Fixing Mode" ZZR-250
04' Red and Black 21sp Repco Mountain bike
ZZR_Bandit, In this article you mentioned coils, where are these located?
Demon
Demon
- gmeddy
- Bike: ZZR250
- State: Western Australia
- Location: Kununurra W.A (Just over the boarder from N.T)
if you haven't yet found them, they are attached to the spark plug leads...
