HELP: removing zx9 font wheel
- Wardy
I know how to get it off but where can I get a 22mm inhex socket 1/2" drive.
I found this on ebay
http://cgi.ebay.com.au/KAWASAKI-ZX-ZRX- ... dZViewItem
and this
http://cgi.ebay.co.uk/kawasaki-zx6r-zx7 ... dZViewItem
Was hoping to get something from Australia. Any help would be appreciated.
Russ
and this
Russ
- Poyda
You may surprised at how loose it is. When i had to get mine off i didnt have the proper tool, so found something that fitted. It turned out to be the flat head of some dodgey old hammer i had in the tool box. It want very tight at all and did no damage to the nut. Whe3n i refitted if i tithgten it up toomuch it over loaded the bearing.
So have a look around the garage, you might just find something.
Otherwise try a tool shop, not bunnings, a propper tool shop and tell them what you want. They'll probably have smaller sizes in stock
Pete
The (no longer) ugly 96 ZX6R
- Wardy
Thanks, never even thought to look there. Now I've just got to find it. Don't think I've even opened it since the first day I bought the bike.matchan wrote:I think you'll find one of the tools in the oem kit fits either end of the axle, it may be the plug spanner.
one end will fit the 22mm side the other will fit the smaller 17/18?mm side.
where are you?
- Wardy
Checked a heap of shops, totaltools, snap on, repco, coventry, glenfords, and a few more, but no luck with a 1/2" drive, can get it in 3/4 but then need and adaptor which ends up being about $90. Will spend a couple more days on it and then if no luck will order from the UK.Poyda wrote:You may surprised at how loose it is. When i had to get mine off i didnt have the proper tool, so found something that fitted. It turned out to be the flat head of some dodgey old hammer i had in the tool box. It want very tight at all and did no damage to the nut. Whe3n i refitted if i tithgten it up toomuch it over loaded the bearing.
- swabio-ACT
thats *exactly* how you do it. 22mm inhex sockets are in the same drawer as the hens teeth and the rocking horse shit....zedex wrote:leave the 2 small hex bolts on that side done up and only use the 17mm on the other
On the 12, first time I did a wheel change, I had to weld a 17mm bolt through a piece of 1" waterpipe that was almost a metre long
For some reason the front axle nut on the 12's gets really tight...
- Neka79
- Extreme Post Whore :-)
- Bike: Z900
hahah u blew $3.50??Loz wrote:I paid $3.50 for an allen key in this size.... Then came home and found there was one in the OEM toolkit.
i bought a hose fitting at bunnings from the $3 box (mine was stuffed)..then got home & saw the receipt and id been charged $14..then found the spare i had in the laundry..but im too lazy to take it back (and i openned it)...lol
