zx6r 2003 and 2004 differences
- GForce
can someone tell me what the difference is? as i am interested in buying one. still flipping between r6, gsxr600 and zx6r.
ill will ride them all but just want to know the diff between 03 and 04. if they they same then i wont bother looking at the 03 as the 04 has lower kms.
- Plaz
- Team Ninja
To explain what Dave means, take of all your clothes, climb on to the zx2r and smash your balls into the tanks 15 or 20 times........this will simulate a 5 minute ride on an 03-04 zx6r.red_dave wrote:Nothing...GForce wrote:what are the negatives of the 03 and 04 zx6r?
if you don't mind talking in a high pitched voice all the time...
The seat slopes forward towards the tank and they have one of the hardest suspension setups I've come across, so every bump or time you have to brake you'll discover that you can indeed sing those high notes. If you ever have to do an emergency stop you may as well forget having kids.
Having said all that they are a frekin awesome machine and very easy to ride quickly.
Are you buying from a dealer or private?
- GForce
i am going to buy it private. got another 2 months before i buy a new beast so will be looking interstate for one too. thanks for the info mark as now i have pretty much made up my mind on what i want to get.
im sticking to kawa as it is cheaper and gives you more bang for your buck. will most likely get the 04 unless i can find a cheap 05.
cheers guys
cheers guys
- varden
As for the ride of the 04 ZX6R, i found winding off the preload on the rear shock to within 4mm of the top of the thread a big help.
Its factory set up for a 120kg rider...68kg specs my arse!
but other than that....
A top bike, by far the best value for money out there, bound to get you into loads of trouble!!!
- varden
Speak of the devil heres the 636 i sold last year!
http://www.bikesales.com.au/as/search/s ... age=1&x=82
- photomike666
I believe the 03 is considerable faster - it managed the journey from Japan to Aus a whole year quicker than the 04!
im currently on an 03 and i havent had any issues with it.
make sure u set the suspension preload up as soon as u get as i waited a while and kicked my self after i run 30mm on the rear and 37 ont he front and found this is nice and soft for the big bumps (mind u im 110kg)
ive only cracked mt bits on the tank acouple of times and it isnt pleasant but after a couple of kns u get over it but this has to be a pretty big bump mid corner or something
power delivery is strong from 8k to redline (i usually change at around 13 thought)
i can also recomend getting a good set of tyres this will also make a huge differnance as it would on any bike(im currently running conti sport attacks and loving them)
think you will love a 03/04 6r
I've got an 03 and all i can say is: do it!
Its quicker than my mates 05 R6 and my other mates 04 gixxer 600. Can pull a high 10 second quarter mile if you can ride it well enough. Also pretty good in the corners and will wheely on the power no worries.
Basically, you wont be dissappointed. Mine cost 10k about 6 months ago but its in good nick with a few extras, it was from a shop and everything is more expensive over here in WA.
Good luck!
Good luck!
