Derestricted
JetPilot
Derestricted
Post by JetPilot »
Im thinking of deresticting the beast. Cost around $400. Im goin to get more power and smother response on , off throttle, but would like to know does this kill motors? Bad Fuel economy? Do i need to change filters...etc.
Any advice would be great. Has anybody done this b4?
Its a Suzuki GSX-R 1000 2003.
Kawasaki Z1000r 2012
Aussie Ninja
Post by Aussie Ninja »
If you are talking about a TRE doesn't it just give you the same ignition curve as 5th for all 6 cogs? I would have thought it would give you better economy as you'll get a more efficient burn. As long as you can control your wrist :twisted:
1998 ZX6R R.I.P.
2004 ZX10R killed by Roo.
2011 ZX10R
zx12B2
Post by zx12B2 »
i think 5th has a leaner fuel map also so lower gears will now run slightly hotter around town but crisper response also.
use engine ice coolant if it is a problem and maybe wire switch to use thermo fan at stop/slow speeds.
its worth having a look at the osb site (OzSportsBikes) - there are a number of gixxer pilots who have all done this, they will give you all the info you need mate.
JetPilot
Post by JetPilot »
Thanks guys...
will check out osb. :wink:
umm if ur gix1000 dont have enuf power u could always get a zx10r....
you could try http://www.gixxer.com too, waaaaaaaay too many gixxer pilots on there for some reason i still can't fathom ;-)
