http://www.powercommander.com/accelpump.shtml
Anyone tried using this function on the street or track?
For street use, what are good parameters to dial in?
Any info is appreciated!
Ta.
Daz.
The PC3 isn't just about going faster, it is about better rideability and fine tuning of the fuel injection.Wattie wrote:i guess i'll never find out, i cant see myself making the Z go faster when it cant get enough ground clearance to take the bends.
i also rode Elvis about 30 seconds before i rode tha' 9,Pontikat wrote:Wattie sounds like "9 envy" mate , GO'ON YA KNOW YOU WANT TOO .
Big Kev found this feature a few months back & has messed with it a bit. I think alex at Lae set it too the optimum for most conditions.
BTW did u know ya can get a module for variable timing advancement as well
RisingSun.au wrote:I have noticed on the twelve that when you are just ticking over at 60km (Not acclerating or slowing down) at around 3,000 RPM it sounds quite rough. Might have a play and see what it does.
That could simply be your current tune. Had any other mods added recently? Was it a custom map? Try reloading a specific map for your bike and mods from the PC's website.
Has anyone actually used this feature and how would I know if the feature was installed by the previous owner?
I assume you have the PC3 USB, not the older PC 2 or 3?
You would need to plug a laptop into your PC3 and have a look.
Exactly the reason for this thread!!!!rotaboy wrote:i would be interested in finding out what ppl experiances are in regard to this as i woudl have thought the fuel injection system would have already catered for this
