On the OEM indicator, this bolt is 'set' in the plastic of the indicator, and then attaches to the mounting bracket with a nut and some washers. On the aftermarket one, there is a hole to screw the bolt into the indicator, but no bolt is included. After MELTING the OEM bolt out of the OEM indicator, I've discovered it's not a screw at all, but just some patterned metal that was fused to the indicator.
So how do I get a bolt that's got two screwy bits on each end of different sizes that will suit my aftermarket indicator? The bolts aren't included with the indicator, and they cannot be bought seperately, according to the shop. Is this something I'm likely to find in a hardware store? It seems like a pretty specialised design.
