Z1k blackened bits
deafwish
Z1k blackened bits
Post by deafwish »
Wasn't a fan of the shiny silver bits, so I've had a couple of things painted in a nice matt black. I think I now need to paint the grey cover under the seat....? :? Thoughts?
Before:
After:
Daz. :wink:
Cath
Post by Cath »
ooooh, I like the blackening. I reckon it looks much sharper.
I agree with you that it would look good with the under seat section done too. At the moment it looks like three different shades of dark grey (matt black painting, under seat grey, seat grey), whereas if that was black, the matt black would look blacker, and overall less 'busy'.
deafwish
Post by deafwish »
I agree, Cath.
How does matt black wear on high 'rub' areas, such as the under seat section? I'm really not keen on doing a gloss black with a clear coat!
Black bits are good... 8)
Looking good!
I like matt-black and black is best!
you need to do the footpeg/pillion peg/exhaust bracket now :)
deafwish
Post by deafwish »
Wattie wrote:you need to do the footpeg/pillion peg/exhaust bracket now :)
I always rest my heels on the backs of them and I'm thinking powdercoating them is a must, as spraypaint might wear off real quick! You agree?
yep, your feet rub heaps on them, and those plastic buts under the seat rub lots and lots too :)
deafwish
Post by deafwish »
Wattie wrote:yep, your feet rub heaps on them, and those plastic buts under the seat rub lots and lots too :)
Hmmmm........ :(
Any suggestions on what matt/ satin paint to use for the plastic bits, under the seat?
no idea, the standard paint will eventually rub through, so paint with something and be prepared to do it again one day.
James
Post by James »
I blacked out the sidecover and frame cover on my Z750. I went the other way with the pillion peg hanger and riders peg backing plate by polishing them!
yeah the 7fiddy pegs look better coz there're seperate, the 1000 ones are all one piece. grrr!!
i looked at swapping the rear subframe for a 750 one so i could have seperate pegs, but the frame is one piece, not bolted. :(
deafwish
Post by deafwish »
James,
What type of paint did you use?
James
Post by James »
Hey deafwish,
I got it done by a local bike painter when I worked at the dealership. It cost me $20 and took 2 days, so I dont think it was anything too fancy. Looked to me like an enamel based paint.
deafwish
Post by deafwish »
Stage 2 is complete! 8)
Did the underseat side covers matt black and just finished the rearsets.
What a PITA the rearsets were to do! :x
Did it once again with a VHT enamel type spray can!
I'll get some better pics, in better light. 8)
Daz. :wink:
