bike tunred off while riding???????????
rocco
Post by rocco »
hey all,
was riding today when i went to pull back on the throttle and no acceleration?????????
my bike had turned itself off!!!!!!!!
pulled over and started and back to normal.
anyone experianced this b4?
and yes i had fuel and no i didnt accidentally use the engine kill switch
Buck
Post by Buck »
Youve bumped your kill switch methinks. If thats the only symptom.
a dodgy ignition will show up before it gets to that. :shock: Had it happen on bikes where the vent in the tank is shite and a vacum builds up that starves carbies but fuel starve youll feel just cutting out sounds like handlebar hockey :lol:
steve
Felix
State: Overseas
Post by Felix »
Hehehe...yeah I actually hit the kill switch by accident once instead of the hi/lo beam...
- Team Furball -
JetPilot
Post by JetPilot »
Yeah... the kill switch
Kawasaki Z1000r 2012
GForce
Post by GForce »
what kind of bike do you have?
did it stutter before turning off?
Grasshopper
Bike: ZZR1200
Post by Grasshopper »
could be dodgy wiring... vibration or turning handlebars could cause wiring/connectors to become intermittent. best of luck!
Burky
Post by Burky »
Yep i'm with Grasshopper on this one, if you didn't hit the kill switch and it had petrol i would be checking the wiring.
kellz
Post by kellz »
yeh either killswitch or you went over a bump and it has dislodged the side stand slightly but enough to make the automatic turn off switchy thinging work and shut the bike down..
well dont worry about it unless it happens again, if it doesm then you know theres some sort of glitch.
if it doesnt, chalk it up to one of the above anomoli, anama, freak occurances.
blackninja
Post by blackninja »
its like those kiddies rides at the supermarket ya gota keep throwing $$$ into them or it just stops :evil:
03 zx6r blackninja
回転日本語私は実際にそう考える
Grasshopper
Bike: ZZR1200
mmmmm.... dicky sidestand switch. good one, didn't think of that.
onearmed_bandit
blinkers maybe?
Post by onearmed_bandit »
i changed front side blinkers to flush mounts and had one of those rear lights with the rear blinkers incorporated i didnt put the resistors that came with the rearlight in coz i feel blinkers flashing fast have a more noticeable effect to the sometimes blind drivers out there, same thing happened to me at a set of lights at night wen the whole bike just shut down but started few minutes later i got paranoid thinkin someone had some sort of remote control immobiliser lol but as i found out the wiring under my seat would get really really hot then cut out so i took it to shop and they put bigger earth wires in i'd get ur wirin checked this is of course if uve modified any electrical part of the bike otherwise i dont know ur story sounded exactly like mine dude hope it all works out anyway cheers................
"given the right environment anything is possible" oh and im male!
