Need advice
- Stereo
Need advice
So the Suzuki regulator rectifyer is fine, in fact the whole charging system (each piece indivudualy) is fine....
So Suzuki say it is the wiring...... and recommend I take it to an Auto Electrician.....
At a guess the first thing an auto electrician is going to say "take all the fairings off and bring it back".... Will that happen?
Well the auto electrician should have a device that tells them if it is drawing power when all the electrics are turned off so they know if theres a short in the somewhere then they chase it down and fix it.
Mr Sparkle
What was the initial issue if you don't mind me asking ?
There are a few tests you can do at home with a Mulitmeter to determine where the fault resides.
- javaman
- Bike: GPz900
Do a serial connection using a lightbulb between positive terminal and body. With power off, see if it lights up. If it does then unplug the fuses one by one to determine the faulty section.
How did you establish that the charging system is okay ?
http://GPZninja.blogspot.com/
- Stereo
thats what suzuki told me.........javaman wrote:Do a serial connection using a lightbulb between positive terminal and body. With power off, see if it lights up. If it does then unplug the fuses one by one to determine the faulty section.
- Strika
Stereo, if you want to, I think I still have a little doovalacky with some wires and a bulb in it somewhere in my tool box. So pop over with it on Sat AM and we can have a look see for until we either find it, or get bored!Stereo wrote:thats what suzuki told me.........javaman wrote:Do a serial connection using a lightbulb between positive terminal and body. With power off, see if it lights up. If it does then unplug the fuses one by one to determine the faulty section.
- Strika
As I don't own one, then it will have to suffice. One would assume we are looking for a leakage, not the amps or voltage! So I reckon it should do the jobmrmina wrote:strika, it might be handy to use a multi meter instead of the bulb pen.
- javaman
- Bike: GPz900
Then it's better to have a look for yourself. Quite simple actually:Stereo wrote:thats what suzuki told me.........javaman wrote:Do a serial connection using a lightbulb between positive terminal and body. With power off, see if it lights up. If it does then unplug the fuses one by one to determine the faulty section.
1. What is the output of battery charging on the battery itself (should be aroung 13.8v when revved
2. Check the alternator output - should be 40-50v (AC) when revved midrange
3. Check the rectifier (diode) which converts AC to DC..
- Benno
- Bike: Scooter
Being an electrician, I have a fairly good understanding of the stuff! If you want a hand on Sat morning, you have my number mate, give us a yell and I'll pop over to Marty's and stick my nose in there for you!Strika wrote:Stereo, if you want to, I think I still have a little doovalacky with some wires and a bulb in it somewhere in my tool box. So pop over with it on Sat AM and we can have a look see for until we either find it, or get bored!Stereo wrote:thats what suzuki told me.........javaman wrote:Do a serial connection using a lightbulb between positive terminal and body. With power off, see if it lights up. If it does then unplug the fuses one by one to determine the faulty section.
How did you establish that the charging system is okay ?I am not brilliant with electrics, but I reckon using a bit of common sense, and Andi's fine instructions we might be able to figure it out! If not, we'll leave the bodywork off it for the elect to look at!
I have a few multimeter's that we can use. Just let me know.
Vespa!
RG
- State: Western Australia
and you charge $60/hr...Benno wrote:Being an electrician, I have a fairly good understanding of the stuff! If you want a hand on Sat morning, you have my number mate, give us a yell and I'll pop over to Marty's and stick my nose in there for you!
just kidding, most sparkies charge about $70/hr.
