Does anyone have any bright ideas on helmets that are quieter than others?
I got a new one last winter (Shark RSF2i) and its louder than my old cheapy AGV. I tried Mal's Shoei Diabolic on the weekend and it wasn't much better.
Mine makes my ears ring after about half hour and I've resorted to earplugs but hate them. Even the soft foamy work ones hurt after a while.
Any suggestions appreciated
2003 ZZR 600
2005 Very Tough Rocket 250
2010 BMW F 800 R
i got no suggestions on helmets but i have found proper fitting ear plugs to be the solution for me.
Not those foam things cause they often dont seal properly etc - but proper custom made ear plugs.
you can usually buy a pair at bike shows/races etc. I lost one of mine but i have found a DIY kit on the net which should sort me out.
Yes thanks I did see that. I really don't wanna do earplugs though, cause another little problem I have with them is that I usually forget to put them in (like we don't have enough gear to put on already)
2003 ZZR 600
2010 BMW F 800 R
Mizz ZZR wrote:Yes thanks I did see that. I really don't wanna do earplugs though, cause another little problem I have with them is that I usually forget to put them in (like we don't have enough gear to put on already)
i know exactly what you mean
they shit me as well but i figure i better try to use them....
im sure one day i will be glad i did...
A lot of wind noise comes in from under your chin. So often the hats with a high neck line will be a bit noiser, although they will allow you more head movement and be lighter. I remember seeing a fitting in England, an elasticated thing that fitted round the bottom of the hat and would streatch over you hear (or something like that). Idea was to reduce the open hole around you neck, without strangling you, and cut out the wind noise. Maybe a big neck scarf would go the same job?
mick_dundee wrote:I have a Shoei RF 900 and it's way quieter than other lids I own, perhpas Shoei stuffed up the engineering on the diabolic.. who knows..
