('99) ZRX1100 carbs
('99) ZRX1100 carbs
Hey there, newbie to site here. Went to the Snowy Ride to Thredbo a few weeks ago, best weather yet. Met a bloke there (Eric) that mentioned the site. G'day Eric if your out there.
Made the trip down and back the long way but had a problem with the carbs last Saturday.
Can anyone assist in finding carby kits for these Keihin's? Straight from Kwaka, as the only, just doesn't ring true. I may be interested in a set of secondhandies if they're out there for the right price.
Primarily I'm looking for info guys. Can anyone help?
Tuck
On the Road & in ur hed
- plane
Try giving Team Show and Go a call....
http://www.showandgo.com.au
They may be able to help out. Your '99 runs CVK36's
What exactly do you need for the bike? I may be able to help out.
Pete
Pete
Live Fast, Die Sideways
ZXR750
- Bike: ZXR750
Re: ('99) ZRX1100 carbs
Speak to Mike at Canberra Motorcycles. He should be able to offer some assistance. Are the carbies fu*%ed or do they just need an icing kit? If so Kawasaki should offer them free of charge, if you catch them on a good day. Phone Kawasaki on 02 9684 2585 ask for Technical services dept. Give them your VIN and ask if the icing kit has been installed if you are unsure.Tuck wrote:Hey there, newbie to site here. Went to the Snowy Ride to Thredbo a few weeks ago, best weather yet. Met a bloke there (Eric) that mentioned the site. G'day Eric if your out there.
- Stereo
Yeah.... good advice! There was an article in the AMCN about it recently...ZXR750 wrote:Are the carbies fu*%ed or do they just need an icing kit? If so Kawasaki should offer them free of charge, if you catch them on a good day. Phone Kawasaki on 02 9684 2585 ask for Technical services dept. Give them your VIN and ask if the icing kit has been installed if you are unsure.
- plane
The ZRX already runs coolant through the carbs to stop them from icing. Is this the kit you are talking about?ZXR750 wrote: Speak to Mike at Canberra Motorcycles. He should be able to offer some assistance. Are the carbies fu*%ed or do they just need an icing kit? If so Kawasaki should offer them free of charge, if you catch them on a good day. Phone Kawasaki on 02 9684 2585 ask for Technical services dept. Give them your VIN and ask if the icing kit has been installed if you are unsure.
Pete
ZRX carbs
Cheers for the help guys. No th ecarbs aren't f$*^!%. I had a sticky set of carbs for a week and when i took a look a new set if needles and seals wouldn't go a stray. Why after only 6years who knows but that's where I'm at.
I'll have a look at showandgo, thanx plane. I'll have a geek at the Newcomers thread also, cheers gosling.
Tuck
- plane
I have a set of standard needles that I could lend you as a fault finding mission. I'll want them back though.
Let me know if you need them.
I'm running a Factory Pro Jet Kit that I got from the States, maybe you could check the price of thiem rather than original replacement parts?
Pete
Pete
ZXR750
- Bike: ZXR750
Kawasaki did a retro fit on a large range of bikes about eight years back. They put a small bottle approx 20ml off the carbies that ran coolant(don't quote me on the technicals)plane wrote:The ZRX already runs coolant through the carbs to stop them from icing. Is this the kit you are talking about?ZXR750 wrote: Speak to Mike at Canberra Motorcycles. He should be able to offer some assistance. Are the carbies fu*%ed or do they just need an icing kit? If so Kawasaki should offer them free of charge, if you catch them on a good day. Phone Kawasaki on 02 9684 2585 ask for Technical services dept. Give them your VIN and ask if the icing kit has been installed if you are unsure.
Pete
I think the ZRX1100 was one of the bikes most were bikes with air ram though.
('99) ZRX1100 carbs
Some great ideas guys. The 'retro fit' is interesting but I like the sound of that Pro kit you have Pete. Would you have the name of the supplier anymore?
They sound like they might have what I'm looking for. I appreciate the lend of the stockies also mate, but I think I'm just going to go that step further.
Tuck
Tuck wrote:.... but I think I'm just going to go that step further.
http://www.zx-12r.org there are a lot of forums other than ZX12R here....
Check out the ZRX1100 forum, there is an *untold* amount of info here, you could spend days and days checking out the topics........just search for *carbie problems*, and heh presto .....also, there are heaps of good links for parts, etc.
- plane
With regards to the jet kit Tuck, check out http://www.wolfracing.com.au They distribute Factory Pro here and should be able to set you up with something locally. Don't discount other jet kits though mate... Dynojet and other brands are only a click away from google!
If you are after a lot of information on the ZRX, check out http://www.zrxoa.com This is an American based board, but there is so much info on it that it is worth checking out. There are a lot of Aussie based rexers on that board as well (I've been a member since 2002).
Pete
Pete
- plane
One other thing you need to check are the throttle cables. They are renound for rusting out and breaking on the rex.
I had one go on me just as I was turning down my street... fortunately I just cranked up the idle speed and got home. Maybe yours are on the way out, which could contribute to poor throttle response.
Keep em well lubed!
Pete
Keep em well lubed!
Pete
Plane is right... the throttle cable return on my '99 snapped ... it was rusted through.... (I had an engine swap and major reworking... and swapped my well maintained stock throttle for one that had been neglected... (read all about it in this months "Rapid Bikes" mag) So lube them up, get the kinks out and see how that goes...
otherwise, buy some 39mm flatslides and watch out or speed cameras.
Texx
Texx
- Errol
Tuck,
I do-not know about the 1100, but I have a 2001 model 1200, they are fitted with carb bowl warming circuit. As I WAS living in the tropical north of QLD I removed mine. Definate reduction in fuel economy. Can-not prove any increase in HP. The US spec ZRX 1200 strangely enough, does not have the carb warming circuit, go figure?
Back in Black 2001
1/4 mile Best MPH 129.47
Best ET 10.747
Best ET 10.747
