so i went out to check out the bike and change the oil. upon removing the oil drain bolt i saw that it was collecting aluminium... but coming out smoothly... putting it back in, it went in smoothly but never tightened properly... so im mighty pissed
so i need either a new oil pan, which looking at hte specs on the ninja 250 is the WHOLE bottom segment of the engine under the crankshaft O.o....
or i can get it drilled and tapped... gah... if anyones got an old ninja or parts i really need your help
... 1st mode of transport so im a little annoyed
