new chain
- Adel
new chain
can some help me please? I went to a bike shop today and got a new
chain put on my zxr 750 and when I took the bike for a run It starts to
get really noisey when I reach 60 k, and seems like something is holding
it from opening up slity is that normal for a new chain to do that, I did
notice the machanic put some of that white grease they put on chains,
could it be he might' ve tensioned the chain to much ? I wouldn't know guys what should the tension be
cheers fellas
cheers fellas
ZXR 750 j 91
- MadKaw
- Administrator
The chain should move up and down about 25 to 30mm on the lower side of the chain.
Also check the rear wheel alignment via the lines on the rear axle washer...
- javaman
- Bike: GPz900
I would suspect the grooves of the sprockets does not match the chain due to wear ? Try loosen up the tension to see if it gets better.
It is generally a good idea to change sprockets and chain at the same time.
http://GPZninja.blogspot.com/
- BikerBoy
I'd definitely recomment changing your sprockets when you change your chain.
The chain is much more expensive than the sprockets, so its not that expensive to do both at the same time.
I'd say thats where you problems are arising, running a new chain with semi-worn out teeth on your sprockets.
I'd try ensuring the tension is right like the guys above suggested and take it for a couple of long rides. This may help by wearing in your chain. If the problem doesn't go away, take it back and replace your sprockets too.
That is if the old sprockets have not already damaged the new chainBikerBoy wrote:I'd definitely recomment changing your sprockets when you change your chain.
not 100 % happy, take it back to the shop.
You might feel a bit silly if it is nothing to worry about.
You might save yourself a bunch of money and some skin if it is something serious that they have fucked up.
Either way, up to you. But I would have it back to the shop.
If your sprockets are worn enough to make a bunch of noise then they are gonna kill your new chain in no time.
