Newbie member here, thanks for having me
I Just changed the oil in the GPX and am a tad worried. I followed instructions and let the oil drain for a good 20 minutes (The old oil), I took it off the centre stand and put up the side stand for good measure as well.
Now, the oil capacity as per the manual is 1.9litres. I would estimate that around 500ml ONLY drained out. It was absolutely putrid/black (First time oil change since I bought it, it has just on 4000km on clock - I bought with 3800km).
Now, I have put the 1.9 litres in, but am now a touch worried I have overfilled it (As per the 500ish that came out)
I did go up/down thru the gears and they felt lovely (Used to clunk a bit).
The small window on the side of the engine was completely empty after I drained it, and is now completely full.
Have I right royally farked this up?
I am not very mechanically minded as you can probably tell
