Micrometer (to measure shims)
- javaman
- Bike: GPz900
Which type should I get ? Saw some cheap ones in Bunnings which is digital and have a resolution of 0.1mm. Is this 'precise' enough?
If not, what brand should I get (and from where) ?
http://GPZninja.blogspot.com/
- Stace
- Team Bolt
- Location: Oakleigh,Victoria. Team BOLT Racing Headquarters
Mic's sould at least measure 0.01mm. A 0-25mm Mic will be all you'll need for shim's. Really the only way to go as far as brands is Mititoyo. Try and stay away from digital ones, I have found them to be not as accurate as the normal veriety and see, to be a bit gimicky to me.
- Smitty
I am with StaceStace wrote:Mic's sould at least measure 0.01mm. A 0-25mm Mic will be all you'll need for shim's. Really the only way to go as far as brands is Mititoyo. Try and stay away from digital ones, I have found them to be not as accurate as the normal veriety and see, to be a bit gimicky to me.
all my measuring gear (caliper dial gauges etc ) are Mititoyo
...which are not cheap btw
and
measuring shims????
all the shims I have ever seen have their thickness screen printed
on 'em ...so no need for micrometers
Smitty wrote:I am with StaceStace wrote:Mic's sould at least measure 0.01mm. A 0-25mm Mic will be all you'll need for shim's. Really the only way to go as far as brands is Mititoyo. Try and stay away from digital ones, I have found them to be not as accurate as the normal veriety and see, to be a bit gimicky to me.
and
measuring shims????
Thats what I thought..
- javaman
- Bike: GPz900
Hey that's genius !!! So you think they don't change in thickness (due to wear) ?
- Stace
- Team Bolt
Yes, However shims will wear over timeDuane wrote:Isnt it generally the distance between the shim and the valve clearence, rather than the shim that changes? hence you measure the distance between the two at a certain point - and find the correct shim for it ?
- Duane
Shimmy shimmy!!!Stace wrote:Yes, However shims will wear over timeDuane wrote:Isnt it generally the distance between the shim and the valve clearence, rather than the shim that changes? hence you measure the distance between the two at a certain point - and find the correct shim for it ?
www.bromancer.com.au
- javaman
- Bike: GPz900
From reading, the process of shims replacement is not as simple as buying a new size shim. As the thickness of the shim will be based on overall condition (determined using a feeler gauge while still installed). Obtaining this number we can get the desired gap if the true thickness of current shim is known
