Removing Bar End Weights
Well, have some goodies en-route which require removal of bar-ends.
How the hell do you get these off?.
I don't want to strip the bolt, but it appears good old Mr. Kwaka has put so much loctite/adhesive on there that I can't get them off.
Any ideas?
Any ideas?
R.I.P Craig William Park. aka 'Skippy'. You may now be resting, but rest assure you will NEVER be forgotten.
16/8/1984 - 10/9/2005
'Born To Ride, Ride Till Die', 'Up On 1', 'Standups 4 Life', '57NTS'
- Aussie Ninja
stevew_zzr
- Duane
A certain knowledgable man once told me a very valuable lesson on working on bikes or cars..
Leveridge is your friend, if a little leverage doesnt work, try alot of leveridge!!!
Get the allen key in the 'hole and get the biggest ring spanner you can find and use it as leveridge!
www.bromancer.com.au
- photomike666
Go with the heat method on the screw to soften the threadlock - the big effort/leaverage may turn the chocolate soft screw into something resembling a smooth round hole.
- Sulli
Q: How can I remove a fastener that is "permanently" locked in?
A: The application of heat is needed to remove a fastener that can't be removed with a hand tool. Temperatures of 325F and above is needed to break down a standard anaerobic, 500F for high temperature Anaerobics. A heat gun or propane torch is commonly used to do this process, and careful disassembly should occur while parts are still hot. Once apart, and cooled, use methylene chloride (Chisel #79040) to remove cured excess material. Always wipe down the fasteners with clean up solvent to remove the wax film that Chisel leaves on the surface.
from the loctite site
http://www.loctite.com/int_henkel/locti ... 4&layout=2
Froggies Soap Box
Its always an education to read post from beginning to end.
Not only to learn (the other reason for a forum besides getting your point across
) but to see how many ppl READ and how many just POST for their own glory therby missing the CORRECT answer several posts back. Lord knows I am not Robinson Caruso here.
So ask your self, in a social situation, say a party, do you lsiten to other ppl to learn OR just wait so you can bless them with your brilliance??
once makes you smarter, the other just removes all doubt
And I didnt hijack the thread, the correct answer was some time back
if your offended look in the mirror
- the kid
Re: Froggies Soap Box
So which one is "CORRECT" ?frogzx12r wrote:Its always an education to read post from beginning to end.
Not only to learn (the other reason for a forum besides getting your point across) but to see how many ppl READ and how many just POST for their own glory therby missing the CORRECT answer several posts back. Lord knows I am not Robinson Caruso here.
And I didnt hijack the thread, the correct answer was some time back![]()
Dare say that Sulli is the Man , but Neil has the
Now just for the rest of us that have had all doubt removed ,
What type of thread locking compound does Kaw use . Is it aerobic or anaerobic , is it "Loctite" brand and if so which number . Also how do you know if the temp has got to 375 F in the area that the compound is . Does a small soldering iron get to 500 + F . What sort of torque would be required to undo said screw when compound is softened ?
Thanking you , judge of all things CORRECT , in advance for the CORRECT answers .
Off to the mirror now
- mike-s
also look at the specs on the loctite website, from memory the gripping ability of the loctite at 250'C (appears to be the magic temperature according to their website) is about 20% of when it is fully cured.
I used a (dick smiths $13 pencil) blowtorch to heat a chassis bolt, mind you by that point i had already frigged my chances of using a easyout by borking the head of it, i just drilled the head off and filed it smooth
then again i had no problems with the other 8 phillip head bolts on the chassis with a rattlegun
[edit]clarification[/edit]
