ZX7-R shift light?
spekt-r
ZX7-R shift light?
Post by spekt-r »
I was looking at some random pics on the net last night of some ZX7's and noticed one had a shift light, the same as those autometer ones, mounted near the guage cluster. Has anyone ever had any success mounting one of these on their bike? This is something that I would like to explore so if anyone has any info please let me know.
"The road to hell is paved with good intentions" screw it then i'll just be bad.
ty
Bike: Honda
re: ZX7-R shift light?
Post by ty »
Don't mean to be a stick-in-the-mud or anything but I've never understood the need for those. Can't you hear when to change gear?
I can see Davezx9r (Dave#2) might be able to use one - but even he can FEEL when to change gear.
Please explain?
Oh, and no I haven't mounted one :D
ty
Quarkz
Post by Quarkz »
Id like to have one. My 5th and 6th gear are so close I can't really hear the difference and Im always pulling in the clutch trying to change up in 6th gear and it annoys me.
I have seen plenty mounted, you can get them from MotoFx. They arent cheap buggers though. I suppose, like a rev indicator (Oh pretty lights) they are just another thing to add "because I could". Hell if I could, I would add one!
Kylie
2013 Kawasaki ZX636 / 2004 Kawasaki ZX636 / 1999 Aprilia RS250
spekt-r
Post by spekt-r »
The idea of shift lights, and the reason I want one, is to indicate the most efficient place to change gear. What I wanna do is have my bike dyno'd see where the power dropps off (if it does) and to see where the I would have to change to get back into the meat of the power curve when I change gears, when Ive found the correct point Ill set the chift light to go BLING (pun intended) when ive hit that point indicating that this is the best place to change gears to keep me in the power.
I absolutely know what youre saying about hearing and feeling but a shift light will give you a more accuate indication of when to change gears so you can keep accelerating most efficiently, thats why drag cars have em.
Hope my explanation helps.
i'd like one but dont know where to get one.
i'm sure if i get one i'll be able to fit it on.
what would be even better would be an lcd screen with the gears on it.
Quarkz
Post by Quarkz »
I have a shift indicator but not a gear indicator. Wish they incorporated one of those into my LCD gauge. Oh, that and a freakin fuel gauge! You can get one here mina: http://www.motofx.com.au/mfpartsinfo.ph ... &mfpro=931
$215 Phwark :?
Kylie
i might look around for some schematics and see if i can make one.
it doesnt look like a big unit. and the way they say its a DIY, it must be a simple design.
i'll check out the web and see what i come up with.
Rossi
Re: re: ZX7-R shift light?
Post by Rossi »
mrmina wrote:what would be even better would be an lcd screen with the gears on it.
and a satellite dish, and a microwave and a kettle and............
Jeez,
can't you remember up to 6 Mina ?
You'd have had no chance with a Derbi 50cc race bike........12 gears and a shit loada fun
Rossi
Post by Rossi »
Spektr
if ya serious mate ? forget the shift light and go straight for the quick shifter, should give you about 8 feet on every gear change
spekt-r
Post by spekt-r »
How does the quick shifter work? what exactly does it do?
spekt-r wrote:How does the quick shifter work? what exactly does it do?
They cut the ignition momentarily to drop the revs so you can change up gears without having to back off the throttle.
Jeez,
mate i have to take my pants off to count til 21.
12 gears on a 50. I guess i'd have to ride with no gloves and one boot to count gears :P
spekt-r
Post by spekt-r »
So they cut the ignition when the clutch is disengaged? sounds cool!
No, just when you put pressure on the gear lever, which means quick clutchless gear changes.
Does anyone actually use the clutch for changing up gears??
