what fuel do you use?
Re: what fuel do you use?
I use exclusively 7-11 fuel ;)
TyM2Go
Bike: Ninja 250
Post by TyM2Go »
Gav wrote:
TyM2Go wrote:well from what ive read the higher the compression ratio the higher the octane rating u can run it on for optimum performance as for ignition timing dont know a whole lot on it but if u set the ignition time for a later period so all the fuel gets burned up before reaching the top dead centre point would
so ill go with compression ratio even tho they both play some what equal parts i could be wrong
i dont know much about it explain your point of view so i can better understand it
Are you really interested in this ...come on mate this has to be a gee up
yeah i am interested whole reason i got into bikes was because of helping my cousin work on his super black bird over the holidays in 2010-2011
want to learn everything from the mechanics of the bike from the basics to everything else so as the years progress ill be comfortable and confident enough in modding/maintaining the bike if ever it gives any problems but what ever your impression of me = squid so lets not bother with fitzy
╭∩╮(︶︿︶)╭∩╮the police.
Kermit
Post by Kermit »
Gosling1 wrote:google *detonation* - that will give you the best explanation :)
Rossco1
Post by Rossco1 »
If you have a high performance such a 6 or higher then i would use BP ultimate 98 but a 250 will do fine with a 95 octane as the ignition point of 98 is not necessary for a 250cc class bike unless you modify the fuel delivery, injectors or re-tune the ECU etc.
TyM2Go
Bike: Ninja 250
Post by TyM2Go »
nope wanted to keep it stock if anything would be considered modding would be the exhaust even that turns out is not a good idea as i don't want to attract the pigs
I use exclusively Liberty Unleaded ;)
Rossco1
Post by Rossco1 »
Stick to 95 then.
JPaddo
Post by JPaddo »
I use exclusively petrol
dickfaber
Post by dickfaber »
Rossco1 wrote:If you have a high performance such a 6 or higher then i would use BP ultimate 98 but a 250 will do fine with a 95 octane as the ignition point of 98 is not necessary for a 250cc class bike unless you modify the fuel delivery, injectors or re-tune the ECU etc.
250 ninjas in australia still use carbies
Rossco1
Post by Rossco1 »
Thanks for the heads up.. that changes everything then :)
ninja250r81
Bike: Ninja 250
Post by ninja250r81 »
remember unleaded 91 will not be sold from june 2012.
shell and a few other servo's are putting ethanol in their 98
so there will be only e10, 95 unleaded, 98 with e10, e85.
then they will phase out 95 unleaded.
government is forcing the issue with carbon blah blah
this is coming from a petrol station owner :(
born green
Post by born green »
ninja250r81 wrote:remember unleaded 91 will not be sold from june 2012.
WTF :shock: :shock:
But dont they have to advertise if its got ethanol in the mix? i dont know, hence the qestion...
96 ZX7R roady
95 tickford XR6,
I thought I read somewhere the other day that this was thrown out...
Possum
Post by Possum »
They did.. It was proposed, there was kaos and the subject went quiet.. :?
http://www.fullyloaded.com.au/industry- ... 77841.aspx
TyM2Go
Bike: Ninja 250
Post by TyM2Go »
well after i empty the tank i am gonna start putting in 95 in the tank going to get about 320 km estimating from the current fuel still a 1/4 of the tank left and im at 275km
