KAWASAKI S2 350 RESTORATION
- TITANIUMBULLET
Re: KAWASAKI S2 350 RESTORATION
thanks for that ! i seen that one on another website. its the clutch release assembly. the previous owner chewed the phillips head screw and i cant get it out. might have to drill it out tomorrow and easy out.let you know
2019 multi 1260 ENDUROTOURER
1972 H2 750 BLUE PRIZED POSSESION THE KING!
1974 H1E GREEN CLASSIC
3 X 72 s2 350 ALL RED
1 X 73 S2 350 BLUE
08 ZX10R WEAPON SOLD08
klx450r bush basher(sold)
05 zx10r titanium(gone)
2 X 06 ZX10r (gone)
07 zx10r track bike(gone)
06 r6 yammy track bike(gone)
1 X 73 S2 350 BLUE
2 X 06 ZX10r (gone)
- kawadave
Cool...glad your sorted.
2013 Motogp tipping champ.
83 GPZ 750 Turbo
78 Z1R 1000
80 Z1R Mk11
07 ZRX 1200r
83 GSX1000sd Katana
83 GPZ 750 Turbo
78 Z1R 1000
80 Z1R Mk11
07 ZRX 1200r
83 GSX1000sd Katana
Stuzrx
- Bike: Z750
Easy outs!!!
....bejeezus,do they still make those mongrel things.There should be a law against those suckers.
If you stuff the cases,I have a spare set of S1 cases you can have for a bourbon + postage.All your other stuff will go straight onto 'em.
Good luck with it.
Good luck with it.
- TITANIUMBULLET
hahah thanks mate , appreciate the offer. let you know!
1 X 73 S2 350 BLUE
2 X 06 ZX10r (gone)
1 X 73 S2 350 BLUE
2 X 06 ZX10r (gone)
- TITANIUMBULLET
success!! well sort of! i couldn't get that screw out ,it was just too tight of a space for the cordless drill so i cheated and bent the other side of clutch release assembly bracket until it was just enough to lift the case off. pics attched.
i need your opinions of the crank. does it look ok , does it need to be rebuilt, bit of surface rust on one side, should i take the risk and put it together with new gaskets and see what happens??
1 X 73 S2 350 BLUE
2 X 06 ZX10r (gone)
1 X 73 S2 350 BLUE
2 X 06 ZX10r (gone)
- kawadave
Difficult to say by looking at the pics.
But ...if you need your crank shaft rebuilt "Triple Cranks" is your man.
Only trouble is he lives in the USA... but I believe his prices are realistic.
http://kawasakitriples.myfastforum.org/ ... file&u=307
83 GPZ 750 Turbo
78 Z1R 1000
80 Z1R Mk11
07 ZRX 1200r
83 GSX1000sd Katana
83 GPZ 750 Turbo
78 Z1R 1000
80 Z1R Mk11
07 ZRX 1200r
83 GSX1000sd Katana
- TITANIUMBULLET
i think i'm going to clean it up and take the risk. it doesn't look too bad.
1 X 73 S2 350 BLUE
2 X 06 ZX10r (gone)
1 X 73 S2 350 BLUE
2 X 06 ZX10r (gone)
Stuzrx
- Bike: Z750
I'd get it looked at 1st ,then decide.
Hey kawadave...don't you know of anyone in Aust??
- kawadave
Sorry Stu I don't....Stuzrx wrote:Hey kawadave...don't you know of anyone in Aust??
83 GPZ 750 Turbo
78 Z1R 1000
80 Z1R Mk11
07 ZRX 1200r
83 GSX1000sd Katana
83 GPZ 750 Turbo
78 Z1R 1000
80 Z1R Mk11
07 ZRX 1200r
83 GSX1000sd Katana
Stuzrx
- Bike: Z750
Apparently there are a number of 2stroke crank builders around Sydney and Brisvegas with a good record.Am waiting for further info.
What does The Gos reckon?? Kawadave....with an apparent number of people available,what made you go to the US???I'm a bit surprise you didn't
investigate Aust 1st !!!
- kawadave
There probably is Stu...Stuzrx wrote: Kawadave....with an apparent number of people available,what made you go to the US???I'm a bit surprise you didn't
I guess its was just a case of someone I knew that would do the right job at the right price.
Lets face it we're all sick and tired of getting ripped off in Aus.
83 GPZ 750 Turbo
78 Z1R 1000
80 Z1R Mk11
07 ZRX 1200r
83 GSX1000sd Katana
83 GPZ 750 Turbo
78 Z1R 1000
80 Z1R Mk11
07 ZRX 1200r
83 GSX1000sd Katana
thats what I would be doing. The important things to check is the play on the rods. A bit of lateral play is OK, you don't want more than about 1mm at the little end. Radial play is way more important - you don't want to feel *any* play if you pull or push the rod on the crank. Nothing. Any play here and you really want the crank rebuilt.TITANIUMBULLET wrote:.....i think i'm going to clean it up and take the risk. it doesn't look too bad......
As for 2T engine/crank builders - my local old-school mechanic has done a couple of 2T singles for me, but does not have the gear for a multi. There used to be a mob in Melbourne who quoted me about a grand to rebuild the H2 crank a few years ago - would have to dig up the contact for this. There was also a couple of good mechanics in Sydney who used to do bottom-ends but they tend to only get work from word-of-mouth. Col Linney was a z9 legend, but he is long gone unfortunately......
As long as you get those cases sparkling clean and the rod play is minimal - the only other real issue is the condition of the crank seals. These are impossible to check unless the motor is together and you can do a leak-down test.
Looking forward to seeing this rig on the road
- kawadave
Just for the record...Gosling1 wrote:There used to be a mob in Melbourne who quoted me about a grand to rebuild the H2 crank a few years ago - would have to dig up the contact for this. .
The crankshaft re builder I mentioned above...charges $350.00, this includes top quality USA made labyrinth seals.
Plus postage back and forth is the killer.
83 GPZ 750 Turbo
78 Z1R 1000
80 Z1R Mk11
07 ZRX 1200r
83 GSX1000sd Katana
83 GPZ 750 Turbo
78 Z1R 1000
80 Z1R Mk11
07 ZRX 1200r
83 GSX1000sd Katana
- steve086
- Bike: Honda
greg ball in Sydney a few months ago rebuilt my dads h2 crank did a top job for what its worth i'd rebuild the crank cause its a bitch to put it back tegther and find out its no good
- TITANIUMBULLET
look what i picked up today!
told you it was going to be a long resto
it was still a bit dusty , i asked for full gloss but it turned out like semi-gloss which i'm still happy about.
1 X 73 S2 350 BLUE
2 X 06 ZX10r (gone)
1 X 73 S2 350 BLUE
2 X 06 ZX10r (gone)
