tuono zrx or z1000?
sillywilly
Re: tuono zrx or z1000?
cheers strika
sillywilly
sman looks good mate u wanna swap ?s man wrote:Go the whole hog & buy this!>>>>>
http://www.ksrc-au.com/phpBB3/viewtopic ... 16&t=41176
sillywilly
zrx might be the go i need to ride one to understand what u blokes love about them cheers and thanks for all the input
I reckon a stock 12 will have more clearance than a 14. But you can tweak the suspension to work better.....which lets you crank it harder......which uses up all available clearancesillywilly wrote:......Yep gos the zx14 is good in most situations except granya i could use a touch more clearance am going to get some rear set plates to lift my pegs a touch only need about a inch that will fix the prob would rather not hang off the bike to much but have to a fair bit .Do u recon a zx12 has much more clearance then a 14 I've owned 2 and id say yes but I'm not sure what u recon?.....
I have not had the chance to take a 14 for a decent strop along a good road like Granya or Reefton, so can only guess at what they would be like. The 14's I have ridden have only been on local roads with not much opportunity to give them a decent pizzling......so they are still an unknown quantity. If Marty was dragging the pegs inside 5 corners, well that just about tells me that they don't have a lot of clearance compared to a 12 ? I have seen his Rex cranked to the max though !
- Nelso
I touched the peg on the ZRX on the deck a couple of times before I had the suspension upgraded and flipped the eccentrics. Since then, they have stayed well clear.
Stuzrx
- Bike: Z750
Bejeezus sillywilly.... man, if ground clearance is your main concern,buy a ZX-10 and be fuckin' done with it.
I had a '99 1100,did 149k over 7yrs,now have an '05 1200 with close to 100k.Both mine from new. I reckon the 11 is the better in the twisty stuff,and the 12 is the better in the wide open stuff.
I love my 12 to death,but should've kept the 11 and spent the money from buying the 12 on 'doing up' the 11.
But I did'nt and am still majorly happy.
sillywilly
Would love to get a 10 but can't sit like that anymore for more then 30 minutes but mayb a zx10 with high bars would be the go
sillywilly
That's cool wattie .how comfortable is it? That looks like the go
Advantage of that is that a Gen 1 ZX-10R (or crim) are pretty cheap these days. I've riden the ubermotard and its pretty comfy, and I'd also say it has more leg room that my ZRX. The leg room is the only thing on a ZRX that could do with some improvement (along with the std suspension but thats fixable)
I wouldnt expect your licience to last all that long on this weapon though.........seems to want to go everywhere like a unicycle
Yeah it's reasonably comfy, but a lot more weight in your ass then used to be. And zx10 seats were not designed with that in mind.
The unicycle thing can be a bit of an issue as Phil says.
Once you get used to the change in handling its ok. You need heavier spring in rear and back the front all the way off.
sillywilly
Thanks everyone for the info .Gos u can come ride my 14 anytime it's fully set up the only thing is u crash it u pay for it .great roads rnd Albury ksrc should have a annual ride down this way kind of half way between Syd Melbs would be great
We dosillywilly wrote: ksrc should have a annual ride down this way kind of half way between Syd Melbs would be great
- born green
Stuzrx wrote:Bejeezus sillywilly.... man, if ground clearance is your main concern,buy a ZX-10 and be fuckin' done with it.
ZX10,s dont have the best ground clearence either, well the 07s sure dont anyway
96 ZX7R roady
95 tickford XR6,
95 tickford XR6,
- Six Addict
- Pinchy
- Bike: Ducati
go the zx10 with the bars... i did it to my ZX6 and it was lots of fun
