How Legal Are....
Re: How Legal Are....
z900/zx9 wrote:Lucky your not in victoria this is a capital offence and u would definatly be booked no matter what, just because they do.I was defected when my reflector was on my guard and it was 45 degress from axle but as some of the guard had been removed they pinged me.It was legal as i went to vic roads and had it removed without question.bottom line is the coppers attitude.
Nah you won't get booked in Vic for an eliminator....as soon as you ride out of your driveway with an eliminator on you'll immediately accelerate into the nearest tree and kill yourself won't you :) They are evil those eliminators
You won't have any drama's in NSW unless you get a cop that is a twat. The 12" rule doesn't work either, my crims tail lights from the factory were barely wider than the number plate. I had an eliminator and an integrated blinker/taillight from day one got pulled over twice for stuff and the issue never came up.
Keep all your stock gear incl exhaust etc just in case you cop a problem and need to get it blue slipped
It looks good so do it. Life's to short to worry about shit
BarraSpalding
Post by BarraSpalding »
SA is said to be hitting the eliminators... but its again only in the hot spots like Gorge Road, chain of ponds etc.
My old zx6r would be alot harder to fix than the new, mud flap is the same moulded plastic as the rear glove box and under seat for battery... so the fact that my rear is cut up to look less shit, if i get defected i'm a little screwed ;)
I don’t care how liberated this world becomes – a man will always be judged by the amount of alcohol he can consume – and a woman will be impressed, whether she likes it or not.
Doug Coughlin (Cocktail)
KEL10R
Post by KEL10R »
Thanks for the info ppl, gone off the idea now..minister of finance is on to me, may have a look again further down the track, cheers.
Went for a ride today and broke in a net set of tyres, discovered the Great North Road from Wollombi down to the servo past the Wisman Ferry Rd turn off, awesome....mid-week rides are the best :kuda:
greenmeanie
Post by greenmeanie »
KEL10R wrote:mid-week rides are the best :kuda:
+1
As a shiftworker i am fortunate enough to get out on a week day(nothin like a mid week RDO/LDO). Very little traffic & lack of revenue raising! :)
Glenn
2009 ZX10R
+1
amen to that. Tuesday afternoons are always a great time for a solo scratch.........and there is a good reason I have always recommended Tuesday arvos.........here it is :lol: :lol:
peace out baby :kuda:
Fred
Post by Fred »
Sorry to resurrect an old thread, but this from the ADR website!
14. WHEEL GUARDS (MUDGUARDS)
14.1. Wheel Guards for Passenger Cars (MA) Vehicles Only
14.1.1. General Requirements
The vehicle must be provided with wheel guards (parts of the bodywork, mudguards, etc) which must be so designed as to protect other road users, as far as practicable, against thrown-up stones, mud, ice, snow and water and to reduce for those users the dangers due to contact with the moving wheels.
14.1.2. Special Requirements
14.1.2.1. The wheel guards must meet the following requirements when the wheels are in the straight ahead position:
14.1.2.1.1. in the part formed by radial planes at an angle of 30 degrees to the front and 50 degrees to the rear of the centre of the wheel (see Figure 1), the overall width (q) of the wheel guards must be at least sufficient to cover the tyre ‘Section Width’ (b) of the tyres fitted to the vehicle taking into account the extremes of tyre/wheel combination as specified by the ‘Manufacturer’;
14.1.2.1.2. the rear of the wheel guards must not terminate above a horizontal plane 150 mm above the axis of rotation of the wheels (as measured at the wheel centres) and furthermore the intersection of the edge of the wheel guard with this plane (point A, Figure 1) must lie outside the median longitudinal plane of the tyre;
14.1.2.1.3. the contour and location of the wheel guards must be such that they are as close to the tyre as possible; and in particular within the part formed by the radial planes referred to in clause 14.1.2.1, they must satisfy the following requirements:
14.1.2.1.3.1. the projection - situated in the vertical plane of the tyre axis - of the depth (p) of the outer edge of the wheel guards, measured in the vertical longitudinal plane passing through the centre of the tyre, must be at least 30 mm. This depth (p) may be reduced progressively to zero at the radial planes specified in clause 14.1.2.1.1; and
14.1.2.1.3.2. the distance (c) between the lower edges of the wheel guards and the axis passing through the centre of the wheels must not exceed 2r, ‘r’ being the ‘Static Loaded Tyre Radius’ of the tyre;
14.1.2.1.4. in the case of vehicles having adjustable suspension height, the above mentioned requirements must be met when the vehicle is in the normal running position specified by the ‘Manufacturer’;
14.1.2.1.5. the wheel guards may consist of several components, provided that no gaps exist between or within the individual parts when assembled; and
14.1.2.1.6. the wheel guards must be securely attached. However they may be detachable either as a unit or in parts.
14.2. Wheel Guards for Vehicles other than MA and L-group Vehicles
14.2.1. General Requirements
All wheels of a motor vehicle or trailer (including a ‘Prime Mover’ capable of operating without a ‘Semi-trailer’) must be provided with wheel guards which must be so designed as to protect other road users, as far as practicable, against thrown-up stones, mud, ice, snow and water and to reduce for those users the dangers due to contact with the moving wheels.
14.2.2. Special Requirements
The wheel guards on the rearmost wheels on vehicles other than MA and L-Group vehicles must provide continuous protection between a point in area A and a point in area B in Figure 2, and must be provided for the ‘Overall Tyre Width’ of all tyres.
14.2.2.1. In the case of steerable wheels, the requirements of clause 14.2.2 must only apply when the wheels are in the straight-ahead position.
14.2.3. Wheel guards may consist of either permanent body structure or part structure and other components, including mudflaps, provided the specified protection is retained during vehicle operation.
14.2.4. Where 2 or more ‘Axles’ form an ‘Axle Group’, separate wheel guards may be provided for each rear wheel or a single wheel guard may be provided which provides continuous protection from area ‘A’ of the foremost wheel to area ‘B’ of the rearmost wheel in Figure 2.
14.2.5. Notwithstanding the requirements specified above the wheel guard including a mudflap (if fitted) need not be less than 230 mm from the ground for other than off-road vehicles, or 300 mm in the case of vehicles designed for off-road operation.
14.2.6. The requirements of this part does not apply to any vehicle the construction or use of which is such that, in the opinion of the ‘Administrator’ it is unnecessary or impracticable to provide a wheel guard(s).
14.3. Wheel Guards for L-Group Vehicles
14.3.1. Wheel guards may consist of either permanent body structure or part structure and other components, including mudflaps, provided the specified protection is retained during vehicle operation.
14.3.2. General Requirements
The wheels of a vehicle and the wheel of a side-car must be fitted with wheel guards of width not less than the ‘Section Width’ of the tyre. The wheel guards must be so designed as to protect other road users, as far as practicable, against thrown-up stones, mud, ice, snow and water and to reduce for those users the dangers due to contact with the moving wheels.
14.3.3. Special Requirements
14.3.3.1. Rear ‘Axle’ and Side-car
The wheel guard provided for the rear wheel and for the wheel of any side-car must extend not less than from a point vertically above the foremost part of the wheel rearward to a point not higher than the intersection of the arc of the wheel guard with a line through the centre of the wheel at 45 degrees to a horizontal plane through the centre of the wheel when a mass of 45 kg is distributed in the saddle of the vehicle at its ‘Unladen Mass’.
14.3.3.2. Front ‘Axle’
Where a wheel guard(s) is provided for the front ‘Axle’, it must extend not less than from a point vertically above the centre of the wheel rearward to a point not higher than the centre of the wheel or to the point where suitable protection is afforded by the frame or other construction of the vehicle when a mass of 45 kg is distributed in the saddle of the vehicle at its ‘Unladen Mass’.
14.4. Visibility of Wheel Guards (Certain Vehicles)
Except when ‘Rear Marking Plates’ are fitted, for every rear wheel guard affixed to a motor vehicle, or trailer which is 2.2 m or more in ‘Overall Width’ and which has a body of the tray type, that portion of the external surface of such wheel guard which is visible to the rear of such vehicle must be white or silver in colour and clearly visible.
14.5 Wheel Guards for MB, MC, MD1, MD2, MD3, NA and NB1 Category vehicles must comply with Clause 14.1 or Clause 14.2.
Fred
badruss
Post by badruss »
Same also, plate only straight under the tail light with no issues and I have been pulled over for lane splitting, copper wasn't concerned about the lack of fender. I do have two bolts with an LED incorporated to attach the plate as a token effort at legal :D
I ran my fender elim for 40,000km with no issues. Then Vic started cracking down and I got defected. Stock unit has been back on ever since.
