thanks for that...ima start looking for some 636 forks...also was going to get braided lines anyway, so might as well do it for the new forks..hmmmm maybe a carbon fibre guard to go with it too..Phil wrote:03-04 forks bolt straight into the Z trple clamps, you'll need longer caliper bolts and 10mm spacers, 00-02 zx6 wheel spacers and the the Z front guard fit straight on. You will also need brake lines 75mm longer then stock![]()
05-06 forks you wont need the brake spacers and longer caliper bolts but you will need the wheel spacers and a new front guard (off a 10 or 6 I believe)
And yes, I have a 04 front end nearly ready to go in - still waiting on some parts to arrive.
Rear is sorted but
what did you do to the rear Phil? my interest is piqued..
