zx12r hp at the wheel
- Benno
- Bike: Scooter
Re: zx12r hp at the wheel
Different dyno's will read different figures. So what 180 is on one dyno might be 150 on another. If you're chasing HP, use a reputed *high reading* dyno. That'll ensure you win the bet.
Vespa!
- shinnynoggon
04/05/06 ZX12R stock with air ram have 187 hp/131kw at the crank
zx12r 05 roady "black betty"
zx12r 00 roady "midori"
zx9r 99 tracky "weed"
- Blue14
- Bike: ZX14R
No 180 at the flywheel, 190 with rammed air at the flywheel. About 159 if i remember at the rear wheel..brendanzxr wrote:Don't stock zx12r's put out 180hp at the wheel?,or just a myth
- Strika
shinnynoggon wrote:04/05/06 ZX12R stock with air ram have 187 hp/131kw at the crank
And i've got a 12 inch dick!
Just like most males, the manufacturers quoted numbers are more often than not, a little optimistic!!!!
- shinnynoggon
according to motorcycle trader on test issue 171 sep 2005 /2005 ZX12R road test /176hp@10,500rpm/ram-air 187hp@10,500rpm/ max torque 13.7kg-m at 7,500rpm
that 'ram-air' figure was only a guesstimate. Its *impossible* to obtain a true hp figure for any bike fitted with ram-air, when its sitting on a stationary dyno-bed. The best you can get is a non ram-air figure, and depending on the dyno, how it is set up, and the 'correction' figures punched into it on the day, dyno figures for any ZX12R can vary between 150hp and 180hp at the back wheel, regardless of mods. Any dyno operator can set up any dyno to obtain whatever figure you want to achieve.*shinnynoggon wrote:according to motorcycle trader on test issue 171 sep 2005 /2005 ZX12R road test /176hp@10,500rpm/ram-air 187hp@10,500rpm/ max torque 13.7kg-m at 7,500rpm
The only way that a *dinkum* ram-air reading could be obtained, is if the dyno was set up in a wind tunnel, with an air stream flowing at 300kmh. This is how the true effect of ram-air could be measured.
Everything else is just pissing up a rope, and in Strika's case, thats using a 12" dick, so he is already 8" ahead of most punters here, but still half an inch behind DonutMan !!
* Check any Gixxer thou dynoe'd on Phil Taintons dyno. There is a K6 up here that apparently has over 200hp at the back wheel.......
- shinnynoggon
lol, going on 3day ride this weekend , booked in at kawa parra when i get back , brad mech will put it on the dyno jet just to see what it's running , let all know what happens with results
my 03 zx12 with pc3 ad yoshi system made 171.4hp 11500rpm using caltex 98 oct
Mines Got: PLENTY HP
- frog
Both my 12s have 178. '05 with full Micron, PCIII and BMC's. '00 with full Yoshi, PCIII and K&N's.
Both on LAE dyno which is NOT optomistic
I am guessing a stock one would put out 160 at least.
And there was a guy here on a Gixxer boasting 300+ speeds, ends up that was on the dyno too
, on the road it wouldnt pull the skin off a cold custard.
Jedi of the darKside
Just because you can ride, doesnt mean you should. My reason on this earth is an example to others what NOT to do.
- 2ndclasscitizen
At least Jarrad only claims his had 198 whpGosling1 wrote:* Check any Gixxer thou dynoe'd on Phil Taintons dyno. There is a K6 up here that apparently has over 200hp at the back wheel.......![]()
- ridden on the street every day, I have heard it running and it has pretty soft cams in it, even the owner reckons it was done on the happiest dyno in the land on the happiest day of the year in fucking Happyland !!!
