Lightbulbs
I think I will highlight it home tonight.... and worry about it tomorrow...
mate its a piece of piss.
as for wattage i probably suggest u dont exceed 100W. If the fuse goes after u have replaced the bulb, it might be an idea to change to a bigger fuse (the wires should handle it) or swap them for lower wattage.
Stereo wrote:
Smitty wrote: ummm Stereo
the big cog wheel ..is usually the light adjuster
turn it one way and the h/light points up, the other points down
The word "FUCK" springs to mind...
we ARE here to help 8)
I am so F*king angry with this F*cking bike right now!!! I cant get the damned little cover fairing off because there is a screw under the F*cking thing! I can only JUST get one hand under there, so I can get the head of the retarted f*king screw f*king driver in there, but I cant get any F*kkking a;slifdjas;dlfkj pressure on there.... and some cl*ver F8cker has F*(ing locktite'd the F*cking thing....
:LISJKF :OIUJHWE:>RJHWER:LIHJWER:LKJWHER:L
The user manual does NOT tell you how to ;oa;lasj;lfjasjl;ase;l replace a lightbulb!
ttc
Team Black
Post by ttc »
stereo are you talking about the bit of black plastic at the top of the fairing near the frame? if so take the 2 allen key bolts out, the other thing you can feel is just a clip, if you wiggle it and pull upwards it will come out :) It's hard but does happen :)
after that, you'll see the round plastic plate, turn it anti clockwise, it's hard too :)
but from there its all go go go :)
jungle
bulbs
Post by jungle »
the bulb would be arctic blues by narva. basicly designed to give off a better brighter white light because you cant put in higher watage bulbs with all the newer vehicles not even with bigger relays cause most headlight assemblys are made out of plastic now that end to melt. part number for a pair of h4 bulbs 48677bl2 norm around $40 retail. sold at most auto shops.also never touch the glass with your hand this will cause to blow the bulb or decrease the life of it dramaticly .clean with metho if you do touch them . :D
THEY KNOW THAT YOU KNOW!!
