HUH WHADIMISS ?.
Can you Polish ?.
the zx6 is pretty dam fast! and its not a whole heap slower, i guess with it being forgiving is, it doesnt make as much torque and for example if u were to get a bit excited out of a corner the zx10r with its gruntly little motor can get a bit of wheel spin happening and cause some noobs to panic and then end up in all sorts of trouble! Where as the 6 is less likely to do it.zx-10r wrote:If your going to upgrade soon anyway, maybe a 10 is ok if you keep your right hand under controll.
Is a 6 really that much more forgiving? How much does a six weigh? i saw figures showing it close to a 10 in a mag but the figures may have been possibly skewed somehow
yes you wring its neck and you want to be fukn holding on, no jokeSaki wrote:the zx6 is pretty dam fast! and its not a whole heap slower, i guess with it being forgiving is, it doesnt make as much torque and for example if u were to get a bit excited out of a corner the zx10r with its gruntly little motor can get a bit of wheel spin happening and cause some noobs to panic and then end up in all sorts of trouble! Where as the 6 is less likely to do it.zx-10r wrote:If your going to upgrade soon anyway, maybe a 10 is ok if you keep your right hand under controll.
Plus the way the 10 comes onto power is so much more extreme than the way the 6 does, the 6 is still fast do not doubt that for 1 second, but its fast in a sense that you really have to ring its neck and it gives you a chance to think "mmmmmmm i am starting to go fast now", plus you can glance at the speedo for a sec and still see you are on earth
But the 10 on the other hand well, you own one you should know, you get yourself all preped to go fast, you ring it, and bam you at point B before you know it!
Have you ridden a Crim before ? Because i found that more extreme than a gubby!zx-10r wrote:yes you wring its neck and you want to be fukn holding on, no jokeSaki wrote:the zx6 is pretty dam fast! and its not a whole heap slower, i guess with it being forgiving is, it doesnt make as much torque and for example if u were to get a bit excited out of a corner the zx10r with its gruntly little motor can get a bit of wheel spin happening and cause some noobs to panic and then end up in all sorts of trouble! Where as the 6 is less likely to do it.zx-10r wrote:If your going to upgrade soon anyway, maybe a 10 is ok if you keep your right hand under controll.
Well i found them to be different. The crim had heaps more mid range power than the gumby, but what the mid range the gumby lack it saw as hell makes for up the top!zx-10r wrote:nah i havent, but if so, that would be crazy
I thought you wre going for a ride?Tinman wrote:bump!
SOLD!Pontikat wrote:$50 posted !!!
Kewel !!!!!!!!!!!!!1 .Saki wrote:SOLD!Pontikat wrote:$50 posted !!!
