Ali600+150 wrote:Nelso wrote:Ali600+150 wrote:1 x hoodie (small) $28 with Slogan A on the back please?
I didn't know that was an option.
It's a "spechial" request
Might not be an option but I'm trying my luck!
Hi Ali,
I'm checking with Rob if it's possible, but it does cause issues (i.e, more issues than a special request for shirts)
Here's what Rob explained to me:
"We don't normally do full back prints on Fleecy lined garments as they move around on the baseboard & can get a ghost print.
To print on black we print 1 white flash cure it ( the heat can shrink fleecy) then we print again & flash cure again, then the green goes on over the white, if the white moves or shrinks the green will not line up & look pretty shitty"
"The KSRC we do on the bottom of the hoodies is relatively easy because of the size we have more control over the print "
So, it's a lot more difficult to get a good product at the end, hence a bigger deal than a similar request for a shirt. Since it's more work and more risk on Rob's behalf (who pays for the bodgy hoodies if 3 stuff up before one comes out well?)- I'm leaving the call up to him. I personally think it takes it out of the realm of a group buy and into the realm of a one-off order (simply because it's not straightforward and the first may not turn out well). Maybe it's possible, maybe it's not, maybe it is at a higher cost, etc...
Anyway - just thought I'd let you know that info
