Aj's zxr250a project
Re: Aj's zxr250a project
Nope, using some spools, I kinda get what ya mean with it tipping forward easily, but I just put a little extra weight on the handle end and it usually sits fine, I agree they're not very well designed..
damo1 wrote:I cant beleave you went to all the trouble to pull the thing down and powder coat the frame and other bits and then just rattle can th ebody work??
If that is just a shit matt black acrylic it will be tough to look after.-- 1 drop of fuel on that tank and it will be rooted, it needs to be done in 2k matt black.
Other than that im lovin what you have done
Cheers damo
Thought I'd tell you that I had a chat with the painter, I've done all the prep work for him, and he's painting it all in 2k matt black and matt clearing everything for me by sometime next week ;D
so you have cut everything back ready to prime in 2K?ajverma wrote:Thought I'd tell you that I had a chat with the painter, I've done all the prep work for him, and he's painting it all in 2k matt black and matt clearing everything for me by sometime next week ;D
yep, except the tank, he's patching it up and going over it with 2k clear, the primer itself is ok to go over with 2k he said, but just on the tank, everything else is getting done over with stripper and he's doing 2k, I've already sanded everything underneath anyway, price is great too, this guy definitely goes down in my recommended list, great to deal with, and he's really friendly and there's no bullsh*t service
You will have to drop a name if it turns out good
I'll run it by him first, he's charging me $200 to do this, which I think is a great price for tank, hugger, front guard and ducktail( 3 pieces) which includes stripping the already crappily painted parts
and filling the crack that I tried to plastic weld so he can get a nice finish on the front guard. I'll ask him if he doesn't mind doing more when I go pick the stuff up, see, he's actually a painter at a smash repairer
Thanks for the advice though mate, never thanked you properly!damo1 wrote:I cant beleave you went to all the trouble to pull the thing down and powder coat the frame and other bits and then just rattle can th ebody work??
Cheers damo
A new update! I've been really busy with uni lately and the bike has gone on the back bench for the last 2 weeks, but I've been doing my scouting for parts, and have got some from someone in Queensland. I got a whole rear subframe to play with and modify to fit some other fairing sets to, and I got a stock exhaust that has been drilled out, I'm getting this one cut in half, (would do it myself but it's welded and I can't weld myself so I can't get it back on). Finally got that battery bracket! Can finish putting the rest of the bike together now. I haven't had a chance to attend to the leaks, so I went out and tried to start the bike today, ran perfectly well, however, it's pissing out oil from the rocker cover. Shit. Really need to realign the gasket around the spark plugs. Here's some photo's of the leak.
AHHHHH when I saw this:
I'm gonna need new leads....
new zorst
oops, I haven't updated this in a little while, well the leaks are fixed, turned out the gasket wasn't installed correctly D'oh! got all the fairings finished and they're great, last leg, brake installation and radiator installation, got the bike towed to bikesmith, turns out there's a bent triple clamp/fork leg, it's about 5mm out, but it's putting my steering geometry out completely, so we're going to bend it back.
- Lurch
- Bike: GPz750
- State: ACT
I just read thru this whole thread - well done man!
Yay no more engine leak
Lurch wrote:I just read thru this whole thread - well done man!
Thanks mate! Appreciate it! My work got recognised, I showed it to Simon at The Bikesmith, and I now volunteer there 1-2 days a week ;D
yep ;D got a helicoil on the sump as well, this way it'll be even stronger then before!robracer wrote:Yay no more engine leak![]()
Have you been to The Bikesmith Rob?
06/10/11
I know it's been ages since I've looked at this and worked on my bike, it's taken a back seat at the moment as I ended up in the business end of my uni semester, though, here's a pic of it sitting in the workshop as it is now, almost complete....
[/quote]
turns out the clamps were slightly out, replacing them, nothing else is damaged, frame is straight and forks are straight, also found both discs warped, replacing them as well, the wheel is also slightly bent, but nothing balancing can't fix.
the clamps are the weak point on this bike for the front end, the forks are much stronger then the clamps it looks like
27/10/11
well the clamps have been replaced, just waiting on front rotors, I have been a bit cheeky, had some money saved and splurged on this:
shouldn't have, but I have now learned how to do wheelies... and I'm trying to sell it to see if I can get the zxr out of the workshop quicker, but if not, the zxr will just have to stay put.. hmm...
I do want to keep it though, but let's see how many visitors I get.
08/11/11
sold the madass about 3 days ago, today I went and put a deposit down for finishing my bike, new tyres going on, metzeler race tec 2 on the front, and still undecided about the back as it's an 18", and I want the best tyres I can buy for the first changeover as I'm going to do a few track days on it.
Bike should be in my hands next week albiet with triple clamps and rotor carriers unpainted, everything else done, just need lights and indicators on for rego.
almost there, just need fork seals done before it gets put back together by next week, after going to superbikes on sunday, I have a fire in my belly that just cannot be put out by looking at bikes any more...
[/quote]
27/10/11
08/11/11
- Deanoseadog
I really want to see this thing finished.
Looks cool. Glad you got that oil leak fixed.....it was a shocker. That whole 18" rear thing sux! Did any other kwakas have a 17x4 rear? Maybe a zxr400, or the Balius? Just a thought.
Soon mate!
thanks for the interest! Stupid me pushed a little ring gasket out of the way when reinstalling the cover...
Going with zxr250C wheels when I can get my hands on a set for cheap, will amke them into track wheels, hopefully with more aggressive tyres, and these two will be more about longevity, will defo be doing soreass campaigns on this bike, don't want to bald the race tec in about 2 months, yearly... that would become so expensive...
- the kid
What are those Madass like to ride AJ ?
Always liked them and think they should be more popular than scooters .
They look like a great commuter .
