HAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHA!!!!!!!!!
think of the $$$$$$$$ i've saved!!!!!!
nothing bad happened (that i know of yet?)
can't kill a kwak engine (knock on my head or wood)
Well, the thing that you would have stuffed up is your catalytic converter. It would have become useless after about 2 kms of your engine running on LRP. And now that you are back on unleaded, you are realeasing an extremly high level to toxic gases. Not the best thing you could have done for the environment or for the person behind you.Yankee wrote:ran my bike on LRP for a year+
The only time you need valve protection is when using an unleaded fuel in an engine designed for leaded fuel. The lead while used to increase the octane also acted as an upper cylinder lubricant and help valve seats, nothing to do with the energy content. You're engine will actually make more power on the lowest possible octane without detonation. It ignites more easily and burns faster. Higher octane fuels are harder to ignite (hence the high octane, resists detonation) and is a slower burning fuel.kypez wrote:
Nice. But they should be careful as engines designed to run on 91 octane might need valve protection with the extra "energy" produced by the high octane fuel.
Also, I wish we got 100 octane like some in america. That would let us bump the compression even higher without messing the heads too much!!
Don't confuse pre-ignition (ignition before the spark plug fires) with detonation / knocking / pinging / pinking. Detonation always happens after a spark induced burn.kypez wrote:The reason we use Premium is to avoid engines from pinging, ie the fuel to self detonate in the cylinder without spark due to temperature and pressure. The result is that it can damage your valves and the cylinder itself by combusting on the wrong stroke.
Couple of things. You CAN damage valves by increasing operating temperature and using high octane fuel that DO increase operating temperatures. Will try find my uni notes somewhere and scan them.Steve_TLS wrote:I'm not picking on you, it might look like it thoughThere's a bit of misinformation there that's all.
Here's a good read on pre-ignition and detonation. Read all 8 pages, it's good. >> http://www.streetrodstuff.com/Articles/ ... etonation/
Mobil LRP used to based on the Synergy 8000 and had a 98 octane rating but was cheaper than the 8000 so I was using it in my ZXR250. It must have been costing them too much because they dropped it back to either 93 or 95 before all the servo's eventually phased LRP out.Smitty wrote:LRP has basically got nothing in it..its a crap petrol, equal to the old
'standard' petrol (low octane) with NO lead
some LRP does have manganese in it to try and prevent
valve seat erosion (not really successful though)
use as much LRP as you like but the bike will
run crap as the octane level is too low for most modern bikes
(I use LRP in the mower mixed with 2 stroke oil..works fine
in the Victa)
Petrol is a mixture of compounds of carbon and hydrogen called hydrocarbons; most of the hydrocarbons in petrol are alkanes. In modern engines, the petrol vapour-air mixture is highly compressed before it is sparked, in order to get the maximum energy from the burning fuel. But, some hydrocarbons tend to ignite under pressure before they are sparked, so that the engine runs roughly; this is known as "knocking or pinking". Branched-chain alkanes tend to resist this pre-ignition better than alkanes with unbranched chains. Alkanes and fuel mixtures are given Octane ratings depending on their knocking tendency. 2,2,4-trimethylpentane (which contains 8 carbons and so is an isomer of octane) has an Octane rating of 100; heptane has a rating of 0. The Octane number of a petrol is the % of 2,2,4-trimethylpentane in a mixture with heptane that has the same knocking characteristics as the petrol under test.The only time you need valve protection is when using an unleaded fuel in an engine designed for leaded fuel. The lead while used to increase the octane also acted as an upper cylinder lubricant and help valve seats, nothing to do with the energy content.
I'm so confused. This is what I had said eariler but the article link has a different meaning for it.Smitty wrote:But, some hydrocarbons tend to ignite under pressure before they are sparked, so that the engine runs roughly; this is known as "knocking or pinking".
The spark starts a burn and the pressure and temperature rises in the combustion chamber, this can cause the spontaneous combustion of the rest of the mixture. Detonation always happens after a spark initiated burn. (But the out of control burn wasn't started directly by the spark)kypez wrote:I'm so confused. This is what I had said eariler but the article link has a different meaning for it.Smitty wrote:But, some hydrocarbons tend to ignite under pressure before they are sparked, so that the engine runs roughly; this is known as "knocking or pinking".
correct SteveSteve_TLS wrote:The spark starts a burn and the pressure and temperature rises in the combustion chamber, this can cause the spontaneous combustion of the rest of the mixture. Detonation always happens after a spark initiated burn. (But the out of control burn wasn't started directly by the spark)
If it ignites before the spark, it's preigniton, but preignition is hard to get to happen in the latter stages of the compression stroke, it will happen much lower when the pressure is low.
