Z1000 Fork Upgrade Complete
- Mattjin
Re: Z1000 Fork Upgrade Complete
Bringing this back from the dead....
I am doing the same fork conversion now and I am surprised how cheap it is. 2004 model ZX6 forks, axle, and calipers for $320 from Fleabay! I sourced the bolts from Nepean Boltmaster. In stainless allen head they cost something like $14 total. All arrived with no bent or damaged parts.
- Six Addict
- Pinchy
- Bike: Ducati
- Mattjin
Slight error there. Boltmaster gave me 1.5mm thread instead of 1.25mm. When I returned them they said they dont do stainless in fine thread, so I grabbed black high tensile instead.
It should be around a week or so before the last of the bits... the back-ordered wheel spacers..... are in my hand.
- Mattjin
Job done! Feels great, very highly recommended for everyone to do this. All up took maybe 2 hours from beginning to end.
Did you upgrade the springs and re-valve? Looks fantastic
I'd suggest wacking a cable tie around the lower fork to see how much travel you are using
- Mattjin
I am using a fair bit of the travel, I am definitely no lightweight! Been using the cable tie check for well over 20 years. All standard for now but I have been contemplating some 1.05 springs in the near future. The dampening seems fine to me so far with the standard ZX6 settings and I think it will stay that way unless the stiffer springs show up a rebound deficiency. It is never going to a track, just purely a road bike so I dont mind it staying on the slightly softer side of what others consider perfect. Interestingly the firmer front end has made the rear feel like it needs a few clicks more rebound, but that is easy to do. I use the ZX6 rear shock too, also a bolt on.
I have to honestly say that anyone with a Zed that is considering some fork work should do this conversion. It costs bugger all, and if you get all the components ready it is a very easy job that anyone can do. We ended up making wheel and caliper spacers rather than buying off the shelf. Actually I have ordered the genuine wheel spacers but they did not arrive so we just made some to suit the OEM Zed spacers. For those interested, OD=40mm ID=25mm Width=2.5mm and you need two of them. The caliper spacers were 10mm thick with a 10mm ID. Cant remember the OD but I can measure it if anyone needs the info. Other than that it all bolts on. I used the 03-04 ZX636 forks and calipers but looking back I should have used the 05 model because I want the newer look front guard. Got these cheap so no real complaints.
- Damon Z1000
I had to do the springs in my 08 conversion. They bottomed out instantly. 1kg springs spot on.
Team Crash 2010 Ooooops
- Mattjin
Did the swap to 1kg springs today and instantly feels better. It doesnt blow through the travel so readily and has allowed me to back off compression dampening a couple of clicks to make it feel less harsh. The springs were also 10mm longer which now brings my preload back into range.
BTW, if anyone is contemplating the conversion I have the wheel spacers available. The ones that we fabricated. The OEM spacers arrived a while ago and the fabricated spacers are now unused.
- Damon Z1000
Nice one welcome to the World of a better handling Zed
I stuck a 55 series profile rear tyre on last time I got new boots - wow, doesnt that sharpen up the steering
- Mattjin
I did the same around a month ago, now running a 190/55. Not to mention new steering head bearings.
- Chitchats
What profile did you have on before the 55?Phil wrote:I stuck a 55 series profile rear tyre on last time I got new boots - wow, doesnt that sharpen up the steering
The stock 190/50 17, the 190/55 supposedly has more meat on the road when leaned overChitchats wrote:What profile did you have on before the 55?Phil wrote:I stuck a 55 series profile rear tyre on last time I got new boots - wow, doesnt that sharpen up the steering
- Chitchats
Might try that next rear,
Thanks
Thanks
- Chitchats
Tell me gents, what sort of travel should the shocks have?Phil wrote:Did you upgrade the springs and re-valve? Looks fantastic
Mine on my commute (no real "hard" braking) i had 70mm of travel.
Fork upgrade done by previous owner.
