The awesome power of a 500cc stinkwheels will do that everytime.......
Here are a couple of pictures of the Wizard, for those who may not have seen it before......
Its a weapon in the dirt alright........here are a basic list of mods to this bike....originally this was a 1984 YZ490L.
+1mm o/s piston kit - capacity of 498.7cc.
Every bearing and seal replaced in a full-tilt bottom end rebuild. New rod. New everything !!
43mm WP forks, originally fitted to KTM300 - rebushed and new seals etc......thanks Dr Bruce !
Wave braking front disc, stock KTM twin-piston caliper, homemade caliper bracket.
FMF Fatty pipe, muffler. Pipe protector
K&N dual-stage air filter
Boyesen dual-stage c/f reeds
jetted by Dr Bruce - goes alright by all accounts
used to have a braced KDX sub-frame !!
re-built and re-gassed stock 490 rear shock
all needle bearings removed from rear shock linkages - replaced by press-fit phosphor bronze bushes, about 6 extra grease nipples fitted.
Afam rear sprocket
DID X-W Gold chain (cost a f/n fortune FFS !!
Brake snake from Geoff Ballard
Full wiring harness and lighting coil from IT175 fitted.
Handlebar risers
Genuine 1986 WR500 front headlight......try and get one of those from Findapart !!
.........and the airbox cover (l/h side) with *genuine* 500 sticker - apparently came from one of Steven Gall's factory YZ500's from the mid-80s'. At least thats what Banksy told me (old owner from ACT Wreckers) - Banger is no bullshit artist, so its probably true. He had lots of good bits in that shop.....
thats the Wizard. It's one fast bike for its age. A bit of a handful in the tight stuff.....but can still go anywhere really, and gets there as quick as any modern off-roader.....
