the bottom butterflies are your throttle the fuel is injected above these but bellow the upper butterflies.
Fast idle/choke
blackninja
blackninja
blackninja
SocialSecurity
- State: Western Australia
blackninja
SocialSecurity
blackninja
SocialSecurity
Are you sure its not like my z750?it has 2 sets of butterflys or throttle plates as mentioned,but the rear set work off a servo motor which is connected to the ecu.The idea of this is so that the engine doesnt over air itself on full throttle openings from a closed postion.So yeah they work as an air restictor,but they are independent of the fast idle lever on the handlebars,which is just that,a fast idle lever.
SocialSecurity
yep, same as spewsukisrocketrod wrote:Are you sure its not like my z750?it has 2 sets of butterflys or throttle plates as mentioned,but the rear set work off a servo motor which is connected to the ecu.The idea of this is so that the engine doesnt over air itself on full throttle openings from a closed postion.So yeah they work as an air restictor,but they are independent of the fast idle lever on the handlebars,which is just that,a fast idle lever.
blackninja
SocialSecurity
blackninja
As I said at the start I slide the fucker up and smell fuel, sometimes I can even SEE it...
BUT just cause my ZX12R does it, has the same lever, (apparently) same general EFI program and has the same probs with aftermarket pipes does NOT mean that it IS a choke (smaller hole) enricher (more fuel) or whatever, it pumps more fuel in for cold morns. Just making it idel higher would not do it.
See the maps for ZX12Rs (not ZRX) and APPARENTLY (ie told by a dealer and Micron) the Zthous are SET. You can fug all you want with inlets and exhausts the MAP aint gonna reset it self.
Taking that into account I would think it would be obvious that it is NOT just a fast idle (sure it makes it idle fast DOH) but is in fact an enricher or choke. Doesnt really matter HOW it gets the extrea fuel whether by rdducing venturi or increasing fuel the results are the same, ie rich.
