Sounds like a Superbike alright Strika!
Not that I can ride like that. With me it goes more like; click 4th, starts to wheelspin, shut the thing off and on again as quickly as possible so it just does a 'mini' highside type thing and try to keep it on track as the wobbles and headshake sort themselves out......
I really must learn to start sliding more and stop chickening out of wheelspin lol. Once it is half way stood up I can ride it out, but man it is scary when you are fairly cranked over and it just starts walking out sideways.......
ZX7R DYNO RESULTS
- Strika
Whats that thing of yours putting out Hemi????? A tuned R1 must be up around those numbers wouldn't it???HemiDuty wrote:Sounds like a Superbike alright Strika!
SocialSecurity
- State: Western Australia
id say the bike is making about the right peak power.. but that dip in the midrange would be pissing me right off
most midrange problems are a bit of a rich spot, id try lowering the needles a clip and see if it feels any better... assuming the needles are adjustable! did the guys dyno'ing it suggest this? they should have
Yeah it is a rich spot and the needles do need to be played with. The factory pro kit comes with emulsion tubes instead of needles which Steve thinks is a better deal in the long run, but needs needles to go the next step. I elected to give it a try and then we'll give it another run and play with some needles. The ignition advancer is set at + 2 degrees to be safe which we might play some more with as well. I'm not on any power mission but just want to optimise what I have. I actually had only riden the bike for approx 40 kms (like a nanna I might add) prior to being dyno'd. Now I'll give it a hard time and see how it goes before we have another play.
Thanks for the interest and info guy's - much appreciated.
Paul.
Paul.
GIVE IT THE BEJEEZUS
