ZX7R mods
greenmeanie
Post by greenmeanie »
Duane wrote:Green Meanie (the 7 already has a slipper clutch, just set very very low, just a cheap mod to do to have it set up right)
Yep i know duane........there is a website link somewhere on the hows etc that has been floating around for years just never bothered with it. :)
Glenn
2009 ZX10R
fat460
Post by fat460 »
Well bike goes to powerhouse at Nerang on Wednesday (dyno tune inc re-jet and fit/set adjustable ignition advancer). Steve has come highly recommended, and can do it before this weekends ride. Will let you know how it goes.
Paul.
GIVE IT THE BEJEEZUS
Duane
Post by Duane »
bloody oath, i know how you feel, it all sounds great, however, I've never had a slipper clutch, so I'm not missing anything
besides, nothing like a bit of backend slide while changing down gears to wake you up in the morning
www.bromancer.com.au
mrmina wrote: - jet kit (supposidely)
Yer not sure? If it runs like pooh (which it should do after installing a full akro system) it hasnt had it done, if it runs great it probably has.... a carborated bike will run really badly when too much airflow is introduced...
well how do u find out :?:
it runs ok in my opinion.
Well, you could check the needles, because the dynojet needles look different than the standard needles.... They will be adjustable, and so they will have a small grooved washer thingee that allows them to move up and down... Which the standard ones dont have (otherwise there is no point in putting them in).
come again.
FrogZ
Post by FrogZ »
Good idea anyway as there was a large batch of Dynojet needles taht were "notched" and filed the jets out..... top shit eh?
fat460
Post by fat460 »
Putting a new clutch in my 7 now as got to 8000rpm on the dyno and zing - drove through the clutch. No big deal, she'll be ready for willowbank now anyway.
Paul.
what needle are u blokes talking about, how about a proper explaination please.
fat460
Post by fat460 »
Picked up the 7 from Powerhouse. Made 114.5 peaking at 11000rpm. Any other 7's been dyno'd, curious how mine compares. Pic of dyno sheet under general discussion.
Paul.
i should get mine done sometime :!:
MBP
Post by MBP »
List of mods i have completed so far.
Floatbowl mod
Ram air tube mod
carbon ram air covers
Led rear flush blinkers
Flush mount front blinkers
rear guard chop
light weight chain guard
520 chain conversion
aluminium rear sprocket
carbon fibre bars
carbon gauge surround
ignition advancer
k and n filter
dyno jet kit
TKA full titanium exhaust
clear rear tail light
single seat tail conversion
superbike sticker kit
light weight aluminium fairing stays
quick release aluminium fairing brackets
working on cast iron brake rotors, rearsets then some more weight saving (mainly carbon fibre and aluminium parts.)
Matt
Greenblood
Post by Greenblood »
Full Muzzy exhaust
K&N filter
Float bowl mod.
4 degree advancer
520 chain with renthal sprocket
Assorted Titanium & aluminum bolts
Ohlin’s rear
Replaced bar ends with lightweight ones
TO DO.
Revalve forks, one day.
FrogZ
Post by FrogZ »
Mina siad "what needle are u blokes talking about, how about a proper explaination please. "
Sorry Mina only picked the question up today.... :oops:
In my case. I dont know if the standard needles had grooves around the top to raise and lower the needles or not. Sounds wierd if they didnt but.
Aftermarket needles generally differ in the taper, that it the original may have had a constant taper but a/m needle may be "flat" in the middle part.
IF you think of it as a "tap" that allows the fuel through it may help.
IF I had a bit of paper it would be VERY easy to explain.
ANYWAY, my input is that Dave Holdforth at Sydney Dyno (who should know as he is a dealer) said that Dynojet had a (large) batch of needles come out that werent smooth but rather notched down the taper due to faulty machining. After a time they actually "filed" the jets out !!!!!
SOOOOO if you have ever put Dynojet needles in and over time it got "fluffy" it MAY be the cause.
