My 7 did the same thing and it was the starter relay. By way of warning if you bypass the relay with a remote starter switch (I wanted to test fire my bike after having it apart) it will crank and not fire as there is also an ignition feed through the relay that you will lose which cuts your spark. From memory the relay was sealed and a genuine only item.
Paul.
ZX7R give me a tap to start HELP!!!!
- Burky
Thanks to all
Have checked all wiring, relays, batt, clutch switch and even the stand switch. started first go sweet i'll go for a blast. Bike off got helmet start it up YOU B***H. 1 kick and hey preso. Anyway 1 week later polished wheels frame and swing arm. if it won't start at least it looks good. Will try again on the week-end.
SocialSecurity
- State: Western Australia
