ZX7 tyre change
jpbikeboy
Post by jpbikeboy »
I think all zx7's run a 6inch rim. the older zxr's run a 5.5inch rim.
greenmeanie
Post by greenmeanie »
jpbikeboy wrote:I think all zx7's run a 6inch rim. the older zxr's run a 5.5inch rim.
All zx7r's have 6inch rear rim.
Glenn
2009 ZX10R
faz
Post by faz »
I have 1 question in regards to this:
since the zx7r has the 6inch rim, most bikes with 180/55 rears a 5.5 inch rim, would putting a 180/55 on a zx7r not improve the turn in?
ie because of stretching the tyre to fit over a wider rim will flatten it?
Just that the 190/55 arent commonly available and I enjoy the extra nimbleness the taller profile rear gives and am thinking of trying 180/55.
Would this then be a waste of switching to 180/55 if it doesnt raise the rear as you would expect a 55 to do.
ZX-7R: Red 7!
Duane
Post by Duane »
I until recently owned a fantastic zx7r.
180 is the way to go, I had a commuter put in, but previous to that had a 207RR (which was good, but utter crap towards the end of its life)
go the 180
www.bromancer.com.au
faz
Post by faz »
The question im asking = is there any difference of a 180/55 on a 6inch rim compared to a 190/50 because of being spread over greater distance.
ZX-7R: Red 7!
Duane
Post by Duane »
I know the question you're asking however, I'm not a frikken tyre fitter so i wouldnt know, Just giving you the opinion of what I found with the 180 compared to the 190
faz
Post by faz »
Duane wrote:I know the question you're asking however, I'm not a frikken tyre fitter so i wouldnt know, Just giving you the opinion of what I found with the 180 compared to the 190
Settle down!
I want to know if a 180 will make any difference at all!
When you went from 190/50 to 180/55, did you go from same brand/type tyre to same brand/type tyre?
If you didnt then how triangular the tyres were may have made the difference in handling. If you did have same brand/type then obviously the 180 doesnt spread flat.
Instead of making "im not a frikken tyre fitter" comments think through the situation and use ur brain to figure out a way to answer questions intelligently.
We are all here for the same purpose and this is a technical discussion!
ZX-7R: Red 7!
Duane
Post by Duane »
Obviously i'm not here for the same purpose as you. Just dont appreciate having my post rejected by you simply reposting the same question, when I actually wasnt answering your question at all considering you didnt start the thread.
I went from dunlop (190) to a bridgy (180) difference was amazing. The profile of the tyre was completely different, and was not flat by anymeans.
Now pull your head in!!. :lol: :lol:
faz
Post by faz »
There you go.
See the difference may have simply been the shape of tyre itself that gave sharper steering.
Anybody have an answer to my question?
ZX-7R: Red 7!
