whoops thought the 1000 came with rebound and compression on the forks and i knew there wasnt much doing adjustability wise at the rear because they where swapping out the stock stuff for 03/04 zx6r shockies.
if you have one rebound adjuster at the front add 2 clicks to it and have another ride that slows down the bounce to reasonable rate doesnt stop the dive but slows it a bit on the way up.
Steve would have adjusted it to what he thought might have worked but missed out on the ride up the local hills.
The only 'other' bike I have ridded was a z750 and I did not like it. Its just different...
andi - Red GPZ900R, GPZ750R1, KLR650 Tengai, KLR250 "my dad's motorbike is cool it is all ways clean.oheter pepole' s motorbikes
are't like my dad's one it's because their is one not always clean." -ariel circa 2007 http://GPZninja.blogspot.com/
even without adjustment im sure a place like promecha could revalve them and set them up nicely for your body weight..... they would wanna get it right tho
AMCN raced a z1000 in the naked bike class a couple of years ago. They modified the forks so both legs had full adjustments.
I don't believe it was that difficult and if I had time I'd find the article..
Terry Hay at shock treatment did it so a call to him may give you some ideas.....
