lol i never really bothered to find out, but to fill the bike with oil, does it go into the right hand side near the rear brake pedal, basically where the clutch cable connects onto ?
TRD_Supra wrote:lol i never really bothered to find out, but to fill the bike with oil, does it go into the right hand side near the rear brake pedal, basically where the clutch cable connects onto ?
have you got a manual yet. if you do it will show you where everything is.
i do have the manual its fora 250C tho and its a photo copy so its hard to tell WTF is going on, also is the oil gauge under the fearing cause i can't find that at all!!!
supra's are alright ey! mine was purely a speed machine, it was an 84 model (MA61) with a newer 3L Turbo dropped in (7MGTE) with an aftermarket ECU, exhuast, injectors, filter, lots of boost!! it could even beat most 250's !!!
ok i have another question now!! the bike manual says it needs an oil grade of either... SE, SF or SG, but the oil i bought is a Repsol oil with Honda spec written on it, but its graded as an SJ.. so should i take it back and get an appropriate grade or will the SJ be fine to use ? cause its oil i bought from a bike only shop!
