ZRX1200r Jet Kit Recommendation
bonester
Re: ZRX1200r Jet Kit Recommendation
Post by bonester »
Good to hear. My high mileage one is perfect at 119000km. :) (R model though)
izzy10r
Post by izzy10r »
Nelso wrote:I have an Ivan's pod kit in mine with a full Akra system and pods. As Glen said, you'll want the full system as the stock headers are very restrictive; they look big, but they are double walled and the inside diametre is small. With the stock headers you will run way rich with any stage 3 kit.
The Ivan's kit is good, but you will need to dial it in on the dyno as it can be a tad rich in spots with some exhausts. I have no idea about the stage 3 dynojet kit on the ZRX, so can't help you there.
What settings are you running with ghe Ivans? I ended up putting a Ivans pod kit. Just wondering if you have the air screw and clip setting. Cheers
